Jim Moore Posted May 20, 2015 Share Posted May 20, 2015 HI Guys, I pulled a couple exhaust studs when I was trying to get the nuts off. I have a pretty good plan to get them back into place, but I need to know the torque for the studs themselves. I didn't see anything in the manual, but I'm not sure I was looking in the right place. Another question. Should I use locktite on the studs? I have blue stuff and super-duper green stuff. Edit to add: It's a 94 R1100RS with a 96 RT engine. Link to comment
cele0001 Posted May 20, 2015 Share Posted May 20, 2015 Just bolt it up and RUN IT already !!!! Link to comment
dirtrider Posted May 20, 2015 Share Posted May 20, 2015 Afternoon Jim I haven't ever seen a torque value for those studs. Most 8x1.25 studs into aluminum are speced to somewhere between 13-15 foot lbs. Personally I just turn them until tight & call it good. You can use Loc-Tite if you want but that area runs so hot that the Loc-Tite will not do any good long term. If you do use Loc-Tite just be sure you use very little & none on the end or the stud as you don't want to hydraulic the hole & damage the cyl head. Just double nut the stud to install. Once in remove both nuts. Link to comment
Jim Moore Posted May 20, 2015 Author Share Posted May 20, 2015 Thanks, DR. Cele, I'm gettin' there. Maybe this week. Link to comment
Denny Pink Posted May 23, 2015 Share Posted May 23, 2015 Hi Jim; Apply copper based anti seize to studs. Exhaust header nuts torque to 15 ft lbs. Easy peazy Link to comment
AndyS Posted May 26, 2015 Share Posted May 26, 2015 Hi Denny, That torque figure for a stud of that size looks about right. However, where did you get the info from? I can't find it in any of my maintenance documentation. Link to comment
dirtrider Posted May 26, 2015 Share Posted May 26, 2015 Morning Andy Denny is giving the torque for the stud NUTS (flange nuts) not the studs into heads. 1100 is 22nm (16.2' lbs) _(it's in the BMW service manual) 1150 is 21nm (15.5' lbs) _(it's also in the BMW service manual) Link to comment
