Great White North Posted May 19, 2015 Share Posted May 19, 2015 Greetings all, I am looking for the specs for the 3 square crimp-on contacts found inside the end of the top spark plug wire connector(Part# 61 12 7 685 348) for my 2004 R1150RT. Had a mishap where I broke the connector, but the damage is limited to the 3 crimp-on contacts (probably 0.75 worth of components).. A new cable is $115 US !! Contacts look something like this: There are 100's of these connectors out there, hoping someone has a part number of model number.. Thanks all. Link to comment
dirtrider Posted May 19, 2015 Share Posted May 19, 2015 Morning Great White North No part number for the terminals (my connector/terminal supply is random access not labeled by part numbers). You can buy the entire connector with terminals & pig tail from BMW motorcycle dealer (very expensive) Or, visit your local BMW car dealer with terminal in hand & they can usually match them up for you at a very reasonable cost. Link to comment
CoolTouch Posted May 19, 2015 Share Posted May 19, 2015 Do you have a soldering iron? With good flux core solder, you can solder the wires onto the remaining connector. Link to comment
waynerd Posted May 19, 2015 Share Posted May 19, 2015 So just yesterday, in our lab, I was crimping some sockets that look dangerously close to what you have pictured (good timing) - might be the ones, or at least provide you with a smaller group to focus on. Do some searching on the Molex C-Grid family of products. Here's some Digi-Key links: THIS is a listing of all the G-Grid sockets that Digi-Key has THIS ONE looks like a close match Maybe you can get some measurements off the sockets you have to verify. I know that it's darn near impossible to find a match for a contact in the sea of choices - unless maybe you spec them for a living. Good luck! Link to comment
Great White North Posted May 19, 2015 Author Share Posted May 19, 2015 Thanks Dirtrider, I've priced the cable, seems like an expensive solution, and if connectors can be replaced, I'll try this at first. Link to comment
dirtrider Posted May 19, 2015 Share Posted May 19, 2015 Thanks Dirtrider, I've priced the cable, seems like an expensive solution, and if connectors can be replaced, I'll try this at first. Afternoon Great White North Do you mean terminals? The connector is the outer plastic part. Link to comment
Great White North Posted May 19, 2015 Author Share Posted May 19, 2015 Yes, I have attempted the solder option, it did work 'somewhat' on two of the connectors, but a third one is unusable and the solder joint becomes a weak spot imo. Would rather have new terminals installed from a reliability point of view. Link to comment
Great White North Posted May 19, 2015 Author Share Posted May 19, 2015 Thanks Dirtrider, I've priced the cable, seems like an expensive solution, and if connectors can be replaced, I'll try this at first. Afternoon Great White North Do you mean terminals? The connector is the outer plastic part. Yes, the square terminals within the connector. Link to comment
