Glacier_g_rt Posted May 1, 2015 Share Posted May 1, 2015 I'm wondering if anyone with the Martin Fabrication auxiliary lights has the same problem I have and has a fix for it. After pressing the on/off button the blue led illuminates but the driving lights don't turn on. I have to tap on each of the lamp housings to get them to turn on. This is required every time I power off the lights that the lamps need a tap to turn on. Anybody have a clue with what's going on? Thanks. Link to comment
dirtrider Posted May 1, 2015 Share Posted May 1, 2015 Afternoon Dave I know nothing about Martin Fabrication auxiliary lights but I do know electrical circuits. As a rule, when you have to tap a light housing to get the light to come on it is either-- -A loose bulb in the socket Or -A bad ground connection, or poor bulb to housing to chassis ground connection. Or A bad power connection Or Failed bulb filaments that only complete connection when jarred. If your grounding is through the housings (no separate ground wire) then that is where I would personally start looking. Link to comment
Glacier_g_rt Posted May 2, 2015 Author Share Posted May 2, 2015 Thank you. They are mounted where the front fender bolts are. Two wires, one of which goes to the negative post on the battery. Guess I will have to disassemble the lights from the look of it. This helps. Thanks again. Link to comment
