Dundee387 Posted May 1, 2015 Share Posted May 1, 2015 your final drive housing and it stained it….. What would you use to try to remove such stain. (white in color), or am I stuck with this.. I tried Simple green motorsports, but that didn't do anything. Link to comment
szurszewski Posted May 1, 2015 Share Posted May 1, 2015 Dirt? Oh wait - you said "remove" - I just cover everything on my bike with a fine layer of rain-caked silt. Makes for a nice, easy to maintain finish Link to comment
dirtrider Posted May 1, 2015 Share Posted May 1, 2015 Morning Dundee387 That could be a tough stain to remove. You might have actually discolored the paint itself so it is not a stain but actual paint damage. Was it just Brake Clean or was there brake fluid involved there also? Link to comment
greiffster Posted May 1, 2015 Share Posted May 1, 2015 Was it just Brake Clean or was there brake fluid involved there also? Yeah. I use brake cleaner to clean a lot of stuff off the drive. I know it's a bit harsh on finishes. But, I bet the stain was from something else. Link to comment
Dundee387 Posted May 1, 2015 Author Share Posted May 1, 2015 I used brake cleaner without the applicator (straw) on the can, and got some on the drive end. I didn't notice it until later , not wiping it off ! And it dried on there.. No brake fluid. Link to comment
dirtrider Posted May 1, 2015 Share Posted May 1, 2015 Morning Dundee387 Assuming normal brake cleaner then that stuff usually evaporates into nothing-left so my long range guess is the brake cleaner actually ate away some of the outer paint layer. Maybe try some auto polish or even a little non aggressive rubbing compound to see if that will partially restore the underlying paint finish. Link to comment
