chrismckay Posted April 7, 2015 Share Posted April 7, 2015 I am contemplating purchasing a set of Denali D2 lamps for my RT1200 2013 I have had a quick look online at the wiring diagram and I need to do the following wiring from the "controll box" I need to connect to a switched 12v supply via a pozi-tap I need to connect to the motorcycle high beam wire via a pozi tap This sounds simple enough until I started reading up on Can-bus, if I just tap into the wires as described will I end up with faults elsewhere in the electrical system? To be honest Can-bus is alien to me Can anybody advise me please.... Chris..... Link to comment
Brian Louw Posted April 7, 2015 Share Posted April 7, 2015 You should be fine as long as you only tap the high beam wire to trigger a relay that powers the Denali's. You will have to get the main power for the relay directly from the battery or an aftermarket fuse box ,else it will throw errors or most likely trip the Canbus circuit for the high beam. Link to comment
chrismckay Posted April 8, 2015 Author Share Posted April 8, 2015 You should be fine as long as you only tap the high beam wire to trigger a relay that powers the Denali's. You will have to get the main power for the relay directly from the battery or an aftermarket fuse box ,else it will throw errors or most likely trip the Canbus circuit for the high beam. Hello Brian, If you have time could you have a look at the diagram on the 3rd page here and let me know if this would be ok and trouble free... http://d1l4i7f87txqmq.cloudfront.net/Installation%20Instructions/Denali/D2/Instructions_TT-D2_rev01.pdf Chris... Link to comment
lkraus Posted April 8, 2015 Share Posted April 8, 2015 In that diagram, the controller takes the place of a relay. All the power comes from the fused red wire that is direct from the battery (or separate fuse block, if you have one). The other connections only provide signals to the controller that the bike is running and the high beam is on or off. The white wire might also power the light in the button. Nothing here should cause any CANBUS problems. Link to comment
Brian Louw Posted April 8, 2015 Share Posted April 8, 2015 In that diagram, the controller takes the place of a relay. All the power comes from the fused red wire that is direct from the battery (or separate fuse block, if you have one). The other connections only provide signals to the controller that the bike is running and the high beam is on or off. The white wire might also power the light in the button. Nothing here should cause any CANBUS problems. Agreed Link to comment
TestPilot Posted April 8, 2015 Share Posted April 8, 2015 In that diagram, the controller takes the place of a relay. All the power comes from the fused red wire that is direct from the battery (or separate fuse block, if you have one). The other connections only provide signals to the controller that the bike is running and the high beam is on or off. The white wire might also power the light in the button. Nothing here should cause any CANBUS problems. You wouldn't have any CANbus problems anyway, since nothing you describe is connected to the bus. Link to comment
