AnalyzeThis Posted January 25, 2015 Share Posted January 25, 2015 I'm unable to hear Nav V through bike speakers. Please Help! Per BMW it should be possible...anyone got this to work? http://www.bmw-motorrad.com/com/en/index.html?content=http://www.bmw-motorrad.com/com/en/equipment/navigation2014/faq/faq_bluetooth_general.html&prm_action=¬rack=1 Can I hear the voice instructions from the BMW Motorrad Navigator V without using a Bluetooth communication system? Yes, you can. Voice messages in the K 1600 GT / GTL and R 1200 RT motorcycles are reproduced in conjunction with the special audio platform accessory via the motorcycle's loudspeakers. If using a car kit for the BMW Motorrad Navigator V (part number 77 52 8 544 460), the voice instructions are outputted through the loudspeakers in the car mounting. Link to comment
narcosis Posted January 25, 2015 Share Posted January 25, 2015 Crazy as it sounds, on the Nav V touchscreen turn the sound off and then back on again. Sound will now come through the speakers. I just verified this on the bike. Same issue when using Bluetooth. Link to comment
AnalyzeThis Posted January 26, 2015 Author Share Posted January 26, 2015 I will be damned. That did work! Thank you for the great tip Ok now this became a 2-part question. What should I set the SRC (Source) button to? If I don't want to listen to radio, but just want for GPS to chime in over the speakers. I set it to unused source like AUX-IN or USB, which seems to work. Just one annoyance...now the dashboard is showing AUX-IN, since the radio is turned on, rather than my usual pick of digital Speedo Link to comment
narcosis Posted January 26, 2015 Share Posted January 26, 2015 I don't have an answer for that one. I've been doing the same as you...picking an unused source. The annoying part of that through Bluetooth is the static hum. Link to comment
Chris in GA Posted January 26, 2015 Share Posted January 26, 2015 I played with wanting to do the same as you, hear just the GPS but no music. I found that the only thing to do was do just what you did and use the line in or USB in with nothing hooked up. But once I got it paired with my old Scala set, it only wants to use the Scala if the Nav V Bluetooth is on. Link to comment
