roger 04 rt Posted January 17, 2015 Share Posted January 17, 2015 I've been working on fueling with the owner of an R1200GS LC. He also has a GS-911 Wifi so is able to log realtime values. The GS LC uses a fly-by-wire throttle, which means that you turn the throttle control on the right handle bar and the computer controls how far to open the TB butterfly. Below is a chart showing how far the BMSK opens the throttle on the vertical axis, based on where the rider positions the throttle control on the horizontal axis. This was an easy ride so the data only shows up to about 40% throttle. There are several interesting things you can see: --The sensitivity of the throttle is lower at small throttle angles, which should make the throttle easier to control. --At idle, closed throttle, the computer opens the throttle up to 15% and varies it based on conditions. --At small throttle settings at the handlebar, there are a wide range of possible throttle valve openings. How the throttle at 10% and the BMSK may use values of throttle opening between 4 and 7% (or degrees, not sure yet which units it uses) I think this chart makes it easy to see that this bike's power control has new dimensions compared to R1150s and R1200s. Link to comment
Guest Kakugo Posted January 17, 2015 Share Posted January 17, 2015 Very interetsing read Roger. Seems they have come a long way since the early production K1600GT I test rode: the throttle on that bike reminded me of the HRC short run throttle I had on mt track bike: it was extremely sensitive even at small throttle angles. Link to comment
dirtrider Posted January 17, 2015 Share Posted January 17, 2015 Morning Roger Interesting, what "ride mode" was that data taken in? Link to comment
roger 04 rt Posted January 17, 2015 Author Share Posted January 17, 2015 Good question DR. Checking that now. Link to comment
roger 04 rt Posted January 18, 2015 Author Share Posted January 18, 2015 Morning Roger Interesting, what "ride mode" was that data taken in? Ride mode was set in Dynamic. Link to comment
hefy_jefy Posted January 27, 2015 Share Posted January 27, 2015 Be really interesting get the same plot for the other modes... Link to comment
