Bald 1 Posted December 9, 2014 Share Posted December 9, 2014 I ride a 2013 R1200RT. I am installing a Wunderlich GPS mount and part of the instructions calls for removing the mirror housing (part of the process in order to get behind the instrument panel). I have been told that in some earlier models, the housing has a quick connect coupling that pops off when smacked smartly on the back corner of the mirror toward the direction of the rear of the bike. Does this work with the 2013 RT? Link to comment
gogs01 Posted December 9, 2014 Share Posted December 9, 2014 I ride a 2013 R1200RT. I am installing a Wunderlich GPS mount and part of the instructions calls for removing the mirror housing (part of the process in order to get behind the instrument panel). I have been told that in some earlier models, the housing has a quick connect coupling that pops off when smacked smartly on the back corner of the mirror toward the direction of the rear of the bike. Does this work with the 2013 RT? I've heard of this (although I thought the technique was to smack it towards the front of the machine) and I'm hoping somebody comes up with a definitive answer. I've also read of safety wires to attach to the mirror pods, which I'm guessing are to prevent the loss of the pod if it pops off unexpectedly ?? Link to comment
walton66 Posted December 9, 2014 Share Posted December 9, 2014 No, unless there is a shortcut I don't know about on my 2013, . Locate the access hole beneath the housing. Inside is a 20 or 25 torx set screw that is reached by pushing the top of the mirror inwards. Unscrew a couple turns and you can pop the mirror out. Behind the mirror are two T30 torx screws that hold the black part of the mirror assembly in place. Remove those and you can remove the assembly and get to the lower screws holding the instrument bezel in place. If you need to remove the rest of the mirror assembly, the part with the turn signal, there is one more T30 screw. The assembly will fall off quickly when you remove that last screw, dammit. Link to comment
cris nitro Posted December 9, 2014 Share Posted December 9, 2014 The smacking off the mirror was on oilheads. And yes you smack it from the mirror side towards the front of the bike to remove it. Link to comment
lkraus Posted December 9, 2014 Share Posted December 9, 2014 The smacking off the mirror was on oilheads. And yes you smack it from the mirror side towards the front of the bike to remove it. My Hexhead comes off with a steady push of the outside edge to the rear, but I think BMW added a screw during the minor restyling of 2010-2013 models. This thread might help: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=847111#Post847111 EDIT: Better Yet! Found instructions with pictures: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=738178#Post738178 Link to comment
gogs01 Posted December 9, 2014 Share Posted December 9, 2014 No, unless there is a shortcut I don't know about on my 2013, . Locate the access hole beneath the housing. Inside is a 20 or 25 torx set screw that is reached by pushing the top of the mirror inwards. Unscrew a couple turns and you can pop the mirror out. Behind the mirror are two T30 torx screws that hold the black part of the mirror assembly in place. Remove those and you can remove the assembly and get to the lower screws holding the instrument bezel in place. If you need to remove the rest of the mirror assembly, the part with the turn signal, there is one more T30 screw. The assembly will fall off quickly when you remove that last screw, dammit. I'm going to give this a go and, if you're right, you've saved me from wrecking my mirrors ! And thanks for the warning about what happens when I remove the last screw !! Link to comment
lkchris Posted December 10, 2014 Share Posted December 10, 2014 Yes, you could smack them off on hexheads but not camheads. The procedure in in the owners manual and the tool kit comes with the required tool. Link to comment
walton66 Posted December 10, 2014 Share Posted December 10, 2014 Kent's right about the tool kit but I found that a set of T15,20,25,&30 torx long drivers is way handier in the shop except for those two bolts for the uppers up under the fork. Link to comment
Bald 1 Posted December 10, 2014 Author Share Posted December 10, 2014 Excellent information. Thanks very much. My only problem now is I think the set screw is stripped. Ugh!!!! Link to comment
Bald 1 Posted December 10, 2014 Author Share Posted December 10, 2014 What a relief!! After much trial and error..I was able to find the exact position to put the T25 in and loosened the set screws. I'm in like Flint! Link to comment
