realshelby Posted February 14, 2006 Share Posted February 14, 2006 I have an '04 RT that I am sure is "Titan" silver. I need to touch up the tupperware and will do this myself. My automotive paint supplier says he can't get motorcycle paint codes. I usually use Dupont products. If I can get a code I may be able to cross it over. Anyone been through this? Link to comment
Boffin Posted February 14, 2006 Share Posted February 14, 2006 I have an '04 RT that I am sure is "Titan" silver. I need to touch up the tupperware and will do this myself. My automotive paint supplier says he can't get motorcycle paint codes. I usually use Dupont products. If I can get a code I may be able to cross it over. Anyone been through this? A quick search using +paint +code came up with this thread which has a link to a site with the paint codes. Cya, Andy Link to comment
realshelby Posted February 14, 2006 Author Share Posted February 14, 2006 I should have thought to do the search myself! I shall punish myself. Meanwhile I think I have what I need to get my paint. Thanks Link to comment
Rob L Posted February 15, 2006 Share Posted February 15, 2006 I have an '04 RT that I am sure is "Titan" silver. I need to touch up the tupperware and will do this myself. My automotive paint supplier says he can't get motorcycle paint codes. I usually use Dupont products. If I can get a code I may be able to cross it over. Anyone been through this? Ask your Dupont dealer to look up the code for a BMW CAR! The codes are the same! This is how I found an exact match for the Biarritz Blue (#363)on my bike, and YES I did use Dupont! Link to comment
realshelby Posted February 15, 2006 Author Share Posted February 15, 2006 Thanks Rob, that was the info I was hoping to find! With the help of those that posted the link to the codes I have the paint code. If it is a match for the cars then I have it made. Link to comment
SWB Posted February 15, 2006 Share Posted February 15, 2006 I have an '04 RT that I am sure is "Titan" silver. I need to touch up the tupperware and will do this myself. My automotive paint supplier says he can't get motorcycle paint codes. I usually use Dupont products. If I can get a code I may be able to cross it over. Anyone been through this? Ask your Dupont dealer to look up the code for a BMW CAR! The codes are the same! This is how I found an exact match for the Biarritz Blue (#363)on my bike, and YES I did use Dupont! That's a COOL tip. I didn't realize that. But I'll go you one better. Forget about the auto codes. Forget about the links to the paint codes referenced earlier. Just go to the source. Look up your bike's make (BMW), model (1100/1150), and year, on a BMW microfiche (A&S BMW has one online). Look up plastics for your bike (should be easy to find, since you'll see six or eight duplicate slides covering each different color). On the same slide that contains part numbers for the plastics, you'll find something that looks like: PAINT, TITANSILBER 354 Terry, your bike's paint code is 354. Link to comment
