walton66 Posted November 22, 2014 Share Posted November 22, 2014 Has anyone ever run across brackets for adding a pair of lights beneath the oil cooler on a 2013 RT. I bought some labeled for 2010 I think but there must be some slight differences because they will not work. I have some hanging on brackets under the mirrors that have kind of a wide pattern but would like a pair with a pretty direct pattern as well. Thanks Link to comment
duckbubbles Posted November 23, 2014 Share Posted November 23, 2014 I ran some Denali lights under the oil cooler, mounting them with to two forward fairing screws under there and the small mounting brackets that came with them. A real PITA to remove the fairing sections. After riding in front of it on a friend's bike, I moved them down to the fender. I figured they are more visible with a little more separation between them and the headlights. I don't have them to see as much as to BE SEEN. Frank Link to comment
walton66 Posted November 23, 2014 Author Share Posted November 23, 2014 yes, being seen!!! I'm planning a cross country retirement trip next year and it is very possible that there will be a few long days to accomplish what I want, hence the desire for another pair. I saw some brackets for the fork legs and calipers that I need to look at as well. Thanks for the feedback. Link to comment
duckbubbles Posted November 25, 2014 Share Posted November 25, 2014 A couple of friends have the Denali's mounted on the fender and when I see them in the mirror, they really stand out. I figured getting them up higher would make them more visible. But after actually seeing mine in the mirror, mounting them lower seemed to be the way to go. Plus doing any maintenance requiring removing any fairing meant they were the first to come off and that was difficult up under there. Frank Link to comment
Blind Squirrel Posted November 25, 2014 Share Posted November 25, 2014 My Denali LEDs are mounted on my forks using the fender screws. I was looking for seperation from the headlights. I am very pleased with how well I can be seen (day or night) and the additional light they give off in the dark. Link to comment
Danny caddyshack Noonan Posted November 25, 2014 Share Posted November 25, 2014 The Ilium works peg mounts allow for not only hiway pegs but have an open tube facing forward (plug inserted). You can drive a nut in or tack weld one into the tube and it makes for a nice location to hang a pair of lights down low. Fabbing up a bracket is fairly simple. Thought I had a picture with those mounts made and Hella micro DEs hung on them. You can see the peg mounts and, on the rider's right side, the plug in the tube. Those are mondo motos mini LED lamps hung under the mirrors. They're still there along with always on fogs on the peg mounts. pic Link to comment
garr2 Posted December 2, 2014 Share Posted December 2, 2014 I bought a Wunderlich Micro-flooter spotlight set from Nippy Normans. The brackets came with the lights. I had them hard wired into low beam which by law in Australia must be on during the day. I wanted to be seen. At night they certainly add to the spread and reach of low beam though they don't penetrate into the far reaches of the darkness. Having said that though I think I now have a greater chance of spotting the kangaroos that are often on the side of the roads around here at night. Ian Link to comment
walton66 Posted December 2, 2014 Author Share Posted December 2, 2014 I thought deer were bad, but a kangaroo ... Wow! Link to comment
