Aussiegazza Posted November 21, 2014 Share Posted November 21, 2014 I am installing a power distribution hub and the rear Powerlet connection does not have enough current to switch a relay. I am assuming that when there is no load on the outlet, the ECU provides little voltage or current. Any other suggestions for a 2014 R1200RT to get switched power to operate a relay? CANBUS is a wonderful thing. Garry Link to comment
AndyS Posted November 21, 2014 Share Posted November 21, 2014 Get your power directly from the battery with a fused input to your distribution hub. Link to comment
Aussiegazza Posted November 21, 2014 Author Share Posted November 21, 2014 I am doing that, but I do not want my Autoswitch to be on continuously (if I can help it). This provides remote garage opening via hi-beam pulsing. I have a Denali PowerHub2 fuse block that can provide both unswitched and switched power (via its own relay). I want to power the Autoswitch and a new Nautilus Horn coming. I wanted to have both switched. The horn can be unswitched without a problem though. The Autoswitch has a red LED on continuously and even though the power draw would be very low, I really want it switched. Garry Link to comment
dirtrider Posted November 21, 2014 Share Posted November 21, 2014 Morning Gerry Is your rear outlet working????? That rear power outlet is not a ramped power source. It provides 10 amps at system voltage (usually between 12 & 14 volts), as long as the front isn't being used. If the front outlet is being used then you need to combine the front/rear use & keep that combined at or under 10 amps. I haven't sourced a low amp key-on power source on the waterhead yet so can't give you a definite place to tap key-on power from. On the older hexhed/camhead 1200RT's I liked the front marker light circuit. You probably do have a key-on power source at the diagnostic connector but that area usually takes taping into a wire so not a seamless non evasive place to grab power from. You might see if anything usable (power wise) in the under-seat fuse box. Link to comment
strataj Posted November 21, 2014 Share Posted November 21, 2014 I am installing a power distribution hub and the rear Powerlet connection does not have enough current to switch a relay. I am assuming that when there is no load on the outlet, the ECU provides little voltage or current. Any other suggestions for a 2014 R1200RT to get switched power to operate a relay? CANBUS is a wonderful thing. Garry That's strange you are having a problem, I'm using one of the fused lines under the front seat, you'll see two of them see page 14 in the user manual. Jay Link to comment
dirtrider Posted November 21, 2014 Share Posted November 21, 2014 Morning Jay Probably a better picture of those fuses & fuse assignments on page 136 of the riders manual. Link to comment
realshelby Posted November 21, 2014 Share Posted November 21, 2014 I used the 15 amp underseat fused circuit to power my lights on the new RT. This was recommended by Skene Design and it has not tripped a CanBus light. Should power a relay properly. The ONLY drawback is that this circuit stays on about 30-40 seconds after you switch off the ignition. Link to comment
Aussiegazza Posted November 21, 2014 Author Share Posted November 21, 2014 I was going to check the fuse box next. Should be just what I need. Thanks all. Garry. Link to comment
Aussiegazza Posted November 22, 2014 Author Share Posted November 22, 2014 Well after going over all the connections, I found a dry solder joint in the new power distribution box. The coil earth was intermittent. Really only held on with silicon. Soldered it up and all good. Garry Link to comment
