Gray Buckley Posted November 13, 2014 Share Posted November 13, 2014 Started about 8,000 miles. Had used 3-4 qt. oil in first 4,000 miles. Inspection reveals leaking valve guide seals, with considerable sludge/deposits lining the internals. Any similar experiences? Link to comment
6speedTi Posted November 13, 2014 Share Posted November 13, 2014 Warranty sounds about right. Link to comment
RandyBailey Posted November 13, 2014 Share Posted November 13, 2014 Gray Rode my 2013 RT from Philly to Phoenix and used less than 1/2 quart. Since then oil consumption has been decreasing. Get yours to the dealer pronto! Link to comment
walton66 Posted November 14, 2014 Share Posted November 14, 2014 15k, very little consumption Link to comment
cris nitro Posted November 15, 2014 Share Posted November 15, 2014 Definitely something wrong, hello Mr. Dealer for a warranty visit. No oil consumption on mine, 13K. Link to comment
Steve R. Posted November 18, 2014 Share Posted November 18, 2014 The subject line said "cold hard starting" so that's what I thought this was about. Mine wants just a little bit of throttle when starting cold with outside temps in the 50's or less. Without the added throttle, it'll fire off enough to disengage the starter but not keep running. With a touch of added throttle, it'll light right off and once stable (5 seconds max) will idle just fine on it's own. As for oil usage, mine needed a counter-balancer seal replacement within a month of taking delivery. It was very interesting seeing my bike literally split in two. The front half (from the engine forward) sitting on the mechanics bike lift and the rear half (from the tranny back) sitting on the center stand, on the floor next to it. So far so good. If I'm using any oil at this point, it's not enough that I can detect it from the sight glass. I'd really prefer a dip stick but can live with what I've got. Like I have any options on that anyway! Ride Safe, Steve R. Link to comment
Gray Buckley Posted November 20, 2014 Author Share Posted November 20, 2014 Started about 8,000 miles. Had used 3-4 qt. oil in first 4,000 miles. Inspection reveals leaking valve guide seals, with considerable sludge/deposits lining the internals. Any similar experiences? Repairs underway per warranty. Dealer provided a loaner. Took from a Tuesday to the following Monday for BMW to authorize. Will be 30 days for parts to arrive from Germany. Link to comment
Gray Buckley Posted February 23, 2015 Author Share Posted February 23, 2015 After replacing the engine control unit it started warm and cold in the shop. One day later it would not start. Tried warm and cold. Going back to the store tomorrow accompanied with a long list of work that has been done and parts that have been replaced. Frustration all around. Dealer has been generous with loaners. Stay tuned. Link to comment
dirtrider Posted February 23, 2015 Share Posted February 23, 2015 Afternoon Gary While in the shop you might have them run a battery load test. Even though it cranks OK the battery voltage might be dropping enough during engine cranking in cold weaather to effect TPS position learning. Link to comment
Denny Pink Posted February 24, 2015 Share Posted February 24, 2015 Hi Gray; Ever miss the R1150? I picked up a 2007 1200RT last fall with 35,000 miles and no problems yet. Fingers crossed! Denny Link to comment
Gray Buckley Posted May 14, 2015 Author Share Posted May 14, 2015 After 6 months of valiant tech effort, have traded the 2013 for a 2015. Included in the deal was a promise to let me know if/when they are ever able to start the bike again and what the problem has been. Link to comment
JayW Posted May 14, 2015 Share Posted May 14, 2015 Well, congratulations on the new bike, but this leaves us with a great mystery. Did they eventually just give up, call the bike a lemon and offer you a smokin' deal to trade up? I too am curious to know that they are going to do with a less than 2 year old motorcycle that won't start. No-starts are usually not that complicated. Link to comment
Gray Buckley Posted May 14, 2015 Author Share Posted May 14, 2015 If/when the issue is identified, I will report it here. Link to comment
Gray Buckley Posted March 8, 2016 Author Share Posted March 8, 2016 After six months of a lot of work, I elected to replace the bike as repair seemed unlikely. Several weeks after receiving my 2015 R1200RT, dealer reported the 2013 suddenly started, inexplicably. Since then it has been sold and there have been no further failures (to start) reported. Link to comment
