oreana123 Posted February 14, 2006 Share Posted February 14, 2006 Just a note to those considering changing your own oil..Walmart stocks a plastic oil filter wrench that costs $3. Tomorrow, I am changing mine. John S Boise It is made for Valvoline and has a 1/4 inch drive metal insert. It is mounted on a cardboard square and is probably hanging near the oil filters. Link to comment
No_Twilight Posted February 14, 2006 Share Posted February 14, 2006 I bought a plastic one at NAPA and it works great. Size is 76-14 and I've posted the NAPA part number before so a search should find it. I agree the plastic is the way to go. The cheap metal ones are too loose and the removed filter jams in it and is a real PITA to remove. Plastic works great. --Jerry Link to comment
ChrisM Posted February 15, 2006 Share Posted February 15, 2006 Just a note to those considering changing your own oil..Walmart stocks a plastic oil filter wrench that costs $3. That's what I use and it's just fine. Link to comment
peterbulgar Posted February 15, 2006 Share Posted February 15, 2006 Won't the use of a non-BMW wrench void your warranty? peter '73 R75/5, '04 R1150RA Link to comment
Softtail Posted February 15, 2006 Share Posted February 15, 2006 K&N makes an oil filter for MCs that has a 17mm nut welded to the bottom. You probably already have a 17mm wrench and would therefore, not need to purchase a special tool for the job. However, if you decide to use the K&N filter, don't tell anyone on this forum!!! <<<<<<Softtail>>>>>> Link to comment
nrp Posted February 15, 2006 Share Posted February 15, 2006 On any oil filter wrench that fits onto the filter-end pattern, be sure the wrench is compltely degreased to increase the effective bite on the filter. I have had trouble with some slipping on the pattern when I forget to. Link to comment
