paRTy Posted September 11, 2014 Share Posted September 11, 2014 Hello- I have a v46 Givi top case that I'd like to mount on a 2014rt. I'm getting differences of opinions. Givi says the E193 will not work on the 2014. They had to take off their catalog. Revzilla shoes an E193 for the 2014. Some folks here say that it works, but doesn't fit great, or right? Givi part for the 2014 (new mount) is not available yet. Aluminum mount for $199. Yikes. Anyone have any pics of the mount on a 2014RT? And if so, are you happy with it? Is it solid. I want my wife to ride with it when she can join me, so safety is utmost. Thanks for your replies in advance. Link to comment
TEWKS Posted September 11, 2014 Share Posted September 11, 2014 Check out this post from ryan_ca1. Proof enough for me that it will work. http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=79020&Number=877213#Post877213 The only issue I could see is a clearance problem with the attachment plates that you have to place on the bottom of your rack. Maybe you'll have to unbolt the rack and mount the plate, then reattach the rack? Pat Link to comment
dasstr Posted September 11, 2014 Share Posted September 11, 2014 My hubby has the 14 RTW and he researched this issue completely. He ended up using the E251 composite mount. He has a v47 topcase . the E251 rack mounts directly to the BMW rack. The bolts supplied by givi are not long enough for the front. You will need to buy ones that are 10mm to 1/2" longer. The finished setup is very secure. Link to comment
paRTy Posted September 11, 2014 Author Share Posted September 11, 2014 thanks.....would you happen to have any pics that show the set-up? Link to comment
dasstr Posted September 12, 2014 Share Posted September 12, 2014 Just read you request for pics! Will try to some this afternoon and post Link to comment
paRTy Posted September 13, 2014 Author Share Posted September 13, 2014 Thanks - appreciate the link. Link to comment
ryan_ca1 Posted September 14, 2014 Share Posted September 14, 2014 I'm using the Givi e193 topcase rack. I took it off my 2006 RT and put in on the 2014. There were zero issues - I used the same bolts, etc. I've been using it daily for months, and it's completely solid. http://www.revzilla.com/motorcycle/givi-e193-topcase-rack-r1200rt-2005-2014 Photos: https://www.dropbox.com/s/sba9rbbt7aokz9l/2014032901.jpg?dl=0 https://www.dropbox.com/s/s9g9ifqzmcyld32/2014032902.jpg?dl=0 https://www.dropbox.com/s/u7s9dqguaiafgtx/Photo%20Sep%2014%2C%202%2008%2033%20PM.jpg?dl=0 https://www.dropbox.com/s/3yfragdbqjb4ksn/Photo%20Sep%2014%2C%202%2008%2043%20PM.jpg?dl=0 Link to comment
Mike the Ghoul Posted March 18, 2015 Share Posted March 18, 2015 Sorry to bring up such an old post. I just installed the E193. It was a little finicky to line up but worked out well. A question I have is did you use a torque setting to tighten the mounting bolts? Or how tight did you make them? Thanks. mike Link to comment
ryan_ca1 Posted March 25, 2015 Share Posted March 25, 2015 I just guessed at hand tight plus a quarter turn. So far, has not come loose over 6,000 miles. Link to comment
SteveA Posted March 29, 2015 Share Posted March 29, 2015 Revzilla seems to be out of stock on the E193. Any suggestions on where else to fine one? Link to comment
gordiet Posted March 29, 2015 Share Posted March 29, 2015 I just bought one through Touratec. They told me it was the only one in the US. Give them a try that was two weeks ago. Good luck. GT Link to comment
paRTy Posted March 29, 2015 Author Share Posted March 29, 2015 Call Revzilla on the phone- I did and asked about the mount and they called GIVI, who in turn had them in stock. Revzilla then sent me an invoice to buy, at their same price. This was a couple weeks ago, so not sure if still available, but Revzilla offered great customer service. I ended up getting the 28L BMW case in the long run from somewhere else, but call them and give it a shot, they may still be able to do the same deal. Link to comment
gordiet Posted March 29, 2015 Share Posted March 29, 2015 Revzilla set me to Turatec! Gt Link to comment
paRTy Posted March 30, 2015 Author Share Posted March 30, 2015 Too funny. Try these guys. Not sure if it's current, but worth a shot. http://www.amotostuff.com/product/E193.html Link to comment
paRTy Posted March 30, 2015 Author Share Posted March 30, 2015 There is also one listed on FleaBay today - used. item number:301578413565 Good luck in your search Link to comment
