Bernie Posted February 10, 2006 Share Posted February 10, 2006 My oil light does not work on my R 1100RT at start up anymore. How do I test it, too find out if it is the switch or the light bulb in the dash? Link to comment
Jim Moore Posted February 10, 2006 Share Posted February 10, 2006 Can you switch the bulb out with another bulb, maybe the neutral light? Link to comment
Ken H. Posted February 10, 2006 Share Posted February 10, 2006 Likely the bulb. If I recall correctly if the pressure switch fails the bike won't run. Link to comment
bmwmick Posted February 10, 2006 Share Posted February 10, 2006 My oil light does not work on my R 1100RT at start up anymore. How do I test it, too find out if it is the switch or the light bulb in the dash? Bernie, The bulbs just pull out from the rear. Maybe enlist a 6 year old to stick his hand in there and pull it for you? To test the wiring, just remove the connector from the oil pressure switch and ground it. That should turn the lamp on. There is no connection from the oil pressure sensor to the Motronics. Bike will run either way. The oil TEMP sensor is the one feeding both the RID and the Motronics. This one can cause problems with engine operation if it's open or shorted. Mick Link to comment
Bernie Posted February 11, 2006 Author Share Posted February 11, 2006 Oh well, the light bulb is fine. It must be the pressure switch. Is there a way to clean it or something. Or is it time to order a new one? Link to comment
Ken H. Posted February 11, 2006 Share Posted February 11, 2006 time to order a new one? Part # 11 411 342 807. $11.20 from Chicago BMW. Link to comment
Bernie Posted February 11, 2006 Author Share Posted February 11, 2006 Thanks Ken, on order. Link to comment
