C Wallace Posted September 4, 2014 Share Posted September 4, 2014 My RT was in the garage all summer for waiting on its new shock. It was just a short ride to the dealer for the repair, but on the way there it was obvious the shift assist had quit working. No amount of pressure on the shift lever would cause it to move unless I relaxed the throttle or clutched. Not the way it worked prior to the stop ride. My dealer agrees that it is broken, but has no idea how to fix it. Says it's too new a system, and he doesn't know that much about it yet. There was a service bulletin on the shift assist that was completed, but had no effect. Has anybody else seen anything like this? Link to comment
JR356 Posted September 4, 2014 Share Posted September 4, 2014 Long thread on shift assist here: http://www.advrider.com/forums/showthread.php?t=932351 Look at the later posts,the early ones are just chatter about"when will it arrive""how good will it be". Some folks reported issues and some fixes suggested. Have debated it for my '14 GSA,but not sure price/benefit is there. JR356 Link to comment
C Wallace Posted September 8, 2014 Author Share Posted September 8, 2014 Thanks for the link. Will try some of the suggestions. Link to comment
bmwdavid Posted September 9, 2014 Share Posted September 9, 2014 Is this a random issue or are there other bikes having this problem? Link to comment
bmwdavid Posted September 9, 2014 Share Posted September 9, 2014 When closing a deal on a new RT the dealer emailed me and said all RT's that have had the shocks replaced now have a issue with the shift assist pro not working and they were working with BMW to resolve the issue. I spoke to another dealer and they only said there was a software update that should resolve everything. Does anyone have any further insight? Has anyone gotten their bike back with issues? Link to comment
C Wallace Posted September 10, 2014 Author Share Posted September 10, 2014 Tried switching ride modes from ROAD to RAIN to ROAD as suggested in the advrider forum, and it fixed the problem completely. Weird, too easy. Link to comment
BitScribbler Posted September 10, 2014 Share Posted September 10, 2014 Just before the "shock" crisis, I took my bike in for it's first service. When I collected the bike and headed down the road I noticed immediately that the quick shifter wasn't working. I returned to the dealer who took the bike into the workshop. Five minutes later the bike was returned, fixed. The dealer explained that after certain updates etc, it was necessary to re-calibrate the system. I didn't get the procedure exactly, but it involved putting the bike on the centre stand and running it up and down the gearbox at idle, leaving it in each gear for a few seconds. Link to comment
mneblett Posted September 10, 2014 Share Posted September 10, 2014 That's not a shift assist-specific issue, although there's no doubt that is exactly what your bike needed. That procedure is used to calibrate the gear position indicator -- I've used it on my 2012 camhead RT while playing around with a GS911. It makes sense that the shift assist won't work if the computer wouldn't understand the gear position indicator signal without the calibration. Link to comment
Pete M Posted September 10, 2014 Share Posted September 10, 2014 Good for you. My SAP never worked well from the start and then stopped working.First repair attempt noted improper voltage at the SAP on computer. New SAP was ordered second attempt, the installed voltage test normal at SAP but not working. After 3 hours of TS the tech through the problem to BMW support. I will call the shop this AM and suggest they get the so called unlock code for SAP. Or have them try switching between ride modes to see if this helps.90 % of the time I am in Dynamic mode. Quite concerned at this point. Link to comment
TarTripper Posted September 10, 2014 Share Posted September 10, 2014 Had the same problem after picking up my repaired bike two days ago. I didn't realise that this was a known issue - thought it was something I was doing wrong. Anyway, after 5 mins and some fiddling with Road Rain Dynamic mode it all cleared. It's been fine since then. Link to comment
Pete M Posted September 11, 2014 Share Posted September 11, 2014 Had the same problem after picking up my repaired bike two days ago. I didn't realise that this was a known issue - thought it was something I was doing wrong. Anyway, after 5 mins and some fiddling with Road Rain Dynamic mode it all cleared. It's been fine since then. Good for you , What were you specificaly doing with the ride modes to get it to work ? Link to comment
hefy_jefy Posted September 12, 2014 Share Posted September 12, 2014 Interesting, I just got my bike (new) after waiting for the shock replacement. I know nothing about SAP except I didn't really want it but it came as a standard feature. I tried it today just to see - seemed just like changing gear without the clutch - v clunky. I will try the Road/Rain/Road thing... Link to comment
Pete M Posted September 12, 2014 Share Posted September 12, 2014 Repaired, the tech had to order a second unit. The system works better as you upshift. Its amazing how fast it upshifts WFO throttle upper revs the system shifts faster than humanly possable. Link to comment
AndyS Posted September 12, 2014 Share Posted September 12, 2014 Its amazing how fast it upshifts WFO throttle upper revs the system shifts faster than humanly possable. That's its job! Link to comment
hefy_jefy Posted September 14, 2014 Share Posted September 14, 2014 Same here, tweaked Rain/Road/Dyno a few times and its working. Actually rather sweet... Link to comment
Pete M Posted September 14, 2014 Share Posted September 14, 2014 Its amazing how fast it upshifts WFO throttle upper revs the system shifts faster than humanly possable. That's its job! Don't you think we know that , I guess not. Link to comment
TarTripper Posted September 17, 2014 Share Posted September 17, 2014 Steady on chaps, don't bite his head off. He's just celebrating one of the many wonderful features and delights of this fabulously good bike. Gear shift assist was one of those things I'd never had and never missed - now I wouldn't be without it. Ye Gods it's good to be back on it again. And screw the BMW naysayers, this is by far the best bike I have ever ridden. Link to comment
TEWKS Posted September 17, 2014 Share Posted September 17, 2014 Any thoughts on smooth down shifting with this system? Upshifts seem smooth enough as long as you're quick and decisive with your left foot. Pat Link to comment
TarTripper Posted September 17, 2014 Share Posted September 17, 2014 Any thoughts on smooth down shifting with this system? Upshifts seem smooth enough as long as you're quick and decisive with your left foot. Pat Only when the throttle is completely rolled-off and decelerating. Never from 3 to 2 or lower. Link to comment
TEWKS Posted September 17, 2014 Share Posted September 17, 2014 I will give that a try, thanks! Pat Link to comment
TarTripper Posted September 18, 2014 Share Posted September 18, 2014 Any thoughts on smooth down shifting with this system? Upshifts seem smooth enough as long as you're quick and decisive with your left foot. Pat Only when the throttle is completely rolled-off and decelerating. Never from 3 to 2 or lower. Apologies 3-2 is fine below about 35 mph. 2-1 is never much fun Link to comment
eej1 Posted September 19, 2014 Share Posted September 19, 2014 2 to one works for me at slower speeds, like the way it blips the throttle any time you shift down. Always with throttle all the way off. Link to comment
TEWKS Posted September 19, 2014 Share Posted September 19, 2014 like the way it blips the throttle any time you shift down. That sounds interesting, I'll get out today and give the throttle off technique a try. Pat Link to comment
AndyS Posted September 19, 2014 Share Posted September 19, 2014 Its amazing how fast it upshifts WFO throttle upper revs the system shifts faster than humanly possable. That's its job! Don't you think we know that , I guess not. Well, from your comment 'Its amazing how fast it upshifts' I would say no. ;-) Link to comment
Alfred02 Posted September 19, 2014 Share Posted September 19, 2014 Try this on downshift: Shut throttle down all the way, then give the throttle a little blip just before the downshift. With a little bit of practice the downshift will be butter smooth. Link to comment
5336G Posted September 19, 2014 Share Posted September 19, 2014 Try this on downshift: Shut throttle down all the way, then give the throttle a little blip just before the downshift. With a little bit of practice the downshift will be butter smooth. This is the method I use; it works perfectly. Link to comment
hefy_jefy Posted October 17, 2014 Share Posted October 17, 2014 You have to be going very slow to downshift in the lower gears and with the throttle fully closed, you CAN get into 1st smoothly but using the clutch is easier... Its cool how it blips the motor. Link to comment
