walton66 Posted September 1, 2014 Share Posted September 1, 2014 working on my 12k today and the clearances have loosened for a couple since the 6k. Specifically the right exhaust valves are right at .4 up from .37 or so, and the intakes are all between .2 and .25 when they were between .15 and .20. The left exhaust are about .36. Those who have more experience with the cammers, what is the result of riding with the exhaust valves so close to the upper limit for a couple of weeks. Link to comment
smiller Posted September 1, 2014 Share Posted September 1, 2014 You have probably severely damaged your engine, try to sell it before it's too late. Just kidding... there is no problem at all with the vales being a few thousandths out of spec for a little while. Besides, the bad thing is clearances that are too tight, not too loose (within reason.) Link to comment
walton66 Posted September 1, 2014 Author Share Posted September 1, 2014 thanks for the help. I don't think I will be able to pull all of the shims today, and I wanted to use new e-clips when I put it back together so It'll be two orders from Max. Link to comment
dirtrider Posted September 2, 2014 Share Posted September 2, 2014 Morning bwpsg42 Personally I try to run the exhaust valves as near the top of spec as I can, or even slightly higher. The older BMW police boxers even specd a looser exhaust valve setting for the police duty bikes. They make just a bit more noise but they live a long life that way. Was the bike overnight cold when you checked yours this time? Link to comment
duckbubbles Posted September 2, 2014 Share Posted September 2, 2014 I wanted to use new e-clips when I put it back togetherThe e-clips are re-useable indefinitely, provided they are not damaged in any way. When manufactured they are stamped out. Look at the two edges- you will notice one side is more rounded and the other has a sharper edge. Install with the sharper edge to the outside- this is aircraft practice- just part of my OCD. Also, running the exhausts (particularly) on the loose side allows them to cool slightly better, remaining on the seat longer to transfer more heat away. Frank Link to comment
walton66 Posted September 2, 2014 Author Share Posted September 2, 2014 this is all good info and I truly appreciate it. I never thought about the valve cooling aspect. Link to comment
