drzep Posted July 27, 2014 Share Posted July 27, 2014 2013 GSA (oil cooled) Can you run the factory GSA fog lights through a fuse block with a different switch? I'm sure you can, but I'm wondering how to power them, and if I need a relay. Pretty sure they use a 7.5A fuse/light. I installed clearwater Kristas on my GSA using the plug-n-play clearwater harness (awesome BTW!). I'd like to also run the factory fogs but through a PDM-60 power distributor and use a switch from cyclenutz. Also have an extra pair of connectors for the OE fogs so it can be a clean install. Any suggestions? Thanks Link to comment
