HH0 Posted July 23, 2014 Share Posted July 23, 2014 I am looking at purchasing a 2006-7 K1200GT and it is my understanding that the braking systems were changed sometime in 2006 to an improved system. I stopped at a BMW dealer today and he said to just stick with a 2007 model. I thought that depending on the date of manufacture for a 2006 you can get the improved system. Can someone enlighten me as to the correct information? Thanks in advance. Link to comment
Dennis Andress Posted July 24, 2014 Share Posted July 24, 2014 K bikes prior to 2007 had the EVO brake system. There is a little servo that powers up when the brake lever is moved off the stop. The effect is not power assist, rather a nudge to overcome the mass of the brake pads and to move them a little bit so they make contact with the disk. The brakes do engage sooner, which takes some getting used to, especially a low speeds. The down side is a complex system where repairs are expensive. Yet, even now failures are still rare. Flushing the brake system is difficult to get right. It may be difficult to find a BMW tech who has experience with that. There are good DIY instructions around here somewhere.... For me EVO was a good thing. I kind of miss the immediacy with which the brakes were applied at speed. Also, when EVO ABS engages, it's a smooth "relaxing" of brake pressure instead of a pulsing on and off. Link to comment
HH0 Posted July 27, 2014 Author Share Posted July 27, 2014 Thanks for the input Dennis. Seems I am more confused than ever now. Dealer said go with the 2007+ as the systems are less expensive to maintain. I haven't found any instructions for flushing these systems but maybe something with show up. Link to comment
dirtrider Posted July 27, 2014 Share Posted July 27, 2014 Afternoon HHO According to my parts book the I-ABS (wizzy) brake system was used until build date of 08/2006 (basically around the start of 2007 bike) After 08/2006 the brake system was changed to the I-ABS gen ll system. I'm not sure you will find a 2006 with the I-ABS gen ll (non wizzy) system but I suppose it is possible a few were built (can't be very many I would imagine). If you are looking at a 2006 long range (like internet) then get the VIN number, then have your dealer run it for build date (you want build date of after 08/2006) Link to comment
HH0 Posted July 29, 2014 Author Share Posted July 29, 2014 thanks dirtrider, I will file that info Link to comment
