BOOCH Posted February 7, 2006 Share Posted February 7, 2006 Does anyone know how to remove the black plastic cover that the ESA rocker switch,is located in??? Does it just pop off or is there a hidden screw somewhere? Thanks Again BOOCH OH,its on my R1200RT.. Link to comment
David_S Posted February 7, 2006 Share Posted February 7, 2006 The following text is from the service manual and an illustration is attached. It looks like the screw is on the bottom side of the handle bar (-) Removing left grip Variant, Heated handlebar grips and Radio with CD player or ESA Removing front remote control unit for radio Release screw (1) on the handlebar-mounted remote-control unit. Remove the housing cover of the handlebar-mounted remote control unit. Release screws (2) and screw (3) and remove the housing of the handlebar-mounted remote-control unit. Link to comment
BOOCH Posted February 7, 2006 Author Share Posted February 7, 2006 David Thank you. I should have known it was'nt a simple " pop off "... Steve Link to comment
David_S Posted February 7, 2006 Share Posted February 7, 2006 Steve the directions are actually for removing the handle bars (sorry I should have stated that) so you may be able to get just the cover off if you can get to the screw. Link to comment
