bubbamoore Posted June 26, 2014 Share Posted June 26, 2014 Has anyone found a solution to the problem with Sirius/XM overdriving the bluetooth inputs? While all my other sources come through clean , XM is totally distorted ( and very loud )at all headset volume levels. Link to comment
eddd Posted June 26, 2014 Share Posted June 26, 2014 I only have old XM units but they have a rudimentary volume adjustment, something on the order of levels 1-5. Check in the menu. Link to comment
strataj Posted June 26, 2014 Share Posted June 26, 2014 Boy it's nice to get back to the old treads. Jay Link to comment
Tri750 Posted June 26, 2014 Share Posted June 26, 2014 Are you using the BMW Comm system headsets in the Schub helmets? Link to comment
bubbamoore Posted June 26, 2014 Author Share Posted June 26, 2014 I was referring to the on board sirius/XM in the R1200RTW audio system and I am using a sena 5 bluetooth headset. Everything comes through clean except XM which comes out extremely loud and distorted. I don't know of a line level volume control for just the XM. Link to comment
AZgman Posted July 8, 2014 Share Posted July 8, 2014 You should be able to adjust the volume, just for the XM feed, on the Sena. I can do this on my Sena 10. (and had the same problem from only one audio source) Link to comment
bubbamoore Posted August 5, 2014 Author Share Posted August 5, 2014 The sena unit is paired with the bike , all audio except the phone ( MP3 , radio , XM , GPS ) come through that pairing. If I were to adjust the sena unit down to compensate for XM , all other audio sources would come out very low volume. Even when using the on board speakers ( non bluetooth ) it is very obvious that the XM is coming in at a significantly higher volume. Link to comment
