gmcjetpilot Posted May 25, 2014 Share Posted May 25, 2014 Sanity check before I go on 1500-2000 mile ride. I finished my oil change. It was easy, followed directions. HOWEVER. I read a lot (too much) and saw a few videos giving me somewhat conflicting information. FINAL DRIVE - It calls for 230ml. The bottle is 948 ml with marks are 900ml, 800ml, 700ml.... I filled to where the bottle level was a tad above 700ml, giving the 230 ml. There is a machined step below the treads in the fill plug port; the oil touches that step. I read several places to "BOTTOM OF THREADS". Well the machined step inside the fill port is below the threads. The true bottom of the plug threads is higher than that step (which I assume is a notch for oil level). TRANSMISSION - It calls for 800ml. I filled to were the 938ml bottle read just above 100ml, giving about 800ml, may be a tad more. I saw a video where they said oil would be just level with the fill hole and seeps out. My level, I can see oil however, but it is below the threads a bit. I did not have a graduated measuring cup (which I'll have next time), but the bottle should be close.... assuming they filled bottle to 948 ml and marks are reasonably accurate. I am assuming +/- 20ml or so is no big deal, and more is not necessary better.... Too much oil can cause loss of HP to rear wheel and foaming. A little less oil is not an issue big issue. Link to comment
eddd Posted May 25, 2014 Share Posted May 25, 2014 The best advice I can give you is that you are good to go. The precise levels are just not that critical so just relax and ride. Link to comment
Stan Walker Posted May 25, 2014 Share Posted May 25, 2014 The best advice I can give you is that you are good to go. The precise levels are just not that critical so just relax and ride. +1. It's not critical at all. For future reference the accepted values are: Final drive: Fill until oil just touches bottom of fill hole downward projection. Transmission: Fill until oil is level with the bottom of the threads (just starts to ooze out the fill hole). Stan Link to comment
gmcjetpilot Posted June 8, 2014 Author Share Posted June 8, 2014 Thanks Gent's - had a great ride 1500 miles all over the great Smokey Mts, in and around Nantahala national forest, blue ridge parkway... TRANS- NEXT TIME Get a measuring cup and fill to 800ml. Bottom of threads seems high from what I saw the level with 800ml. I'll experiment and see how much extra takes to get to bottom of threads next time. If not much extra, I'll allow it. However if it is taking a full liter to get to threads, I'll go back to measured amount. FINAL DRIVE - NEXT TIME 238ml and double check it is to bottom of machined step (below threads). I don't think overfilling a little is a big deal within in reason. However more does not protect more, only causes more drag, possible foaming and possible I hear seals blowing out in FD or oil coming out of breather. Link to comment
AndyS Posted June 8, 2014 Share Posted June 8, 2014 I can't see what the problem is. You drain the oil, fit the drain plug and fill until it is leve, with the bottom of the fill hole. Any excess escapes. Pop the fill cap on. Job done. Link to comment
Selden Posted June 8, 2014 Share Posted June 8, 2014 A small syringe makes adding the last bit of oil (and sucking some out, if too full) easier. Link to comment
hopz Posted June 9, 2014 Share Posted June 9, 2014 Word of advice… do not fill either the Transmission or the Final drive above the fill holes… and you will be fine. Link to comment
