Matts_12GS Posted February 1, 2006 Share Posted February 1, 2006 Hey everyone, I manged to totally hose up one of the screw inserts into the plastic of the RT tank. I tried to search and couldn't find any info on them. Can someone hook a brother up? Matt Link to comment
ShovelStrokeEd Posted February 1, 2006 Share Posted February 1, 2006 Try a tap. Take the screw with you. They are probably 4 x .7 or 4 x .5. I think 8-32 might work as well. If the insert is spinning in the housing you are basically screwed. There are ways to remove these things and you might try a left hand drill bit. Replace with a thing called a Pimm (sp) nut. Link to comment
Ken H. Posted February 1, 2006 Share Posted February 1, 2006 If re-taping it doesn't work or it is rotating in the plastic, and if you're just concerned about the cosmetics aspect of the screw being there (and with the other two OK that's probably the only real issue), remove the now messed up brass insert completely. Then on the fairing piece fasten a shortened screw in place with a nut on the backside of it. No one will ever know but you. Just remember which one it is at the next disassembly! Link to comment
USAF1 Posted February 1, 2006 Share Posted February 1, 2006 Been there....done that!! It worked good! Matts_RT Unless you use a squared off tap, the tapered ones will be bottoming out by the time any threads start catching hold. Not to mention the chance of any drill bits catching, and going al the way thu the tank. Best O'Luck to ya! Pat Link to comment
bigboy Posted February 1, 2006 Share Posted February 1, 2006 HI MATT I did exactly the same thing on mine , i got an old fixing cut off the thread and superglued it onto the tank looks origional and only i know it,s false. stay upright derek Link to comment
Matts_12GS Posted February 2, 2006 Author Share Posted February 2, 2006 Thanks everyone, I'm gonna use the "fake" bolt approach! Link to comment
