Nathan Margolis Posted April 21, 2014 Share Posted April 21, 2014 I have a '13 RT and replaced the front tire over the weekend. Thought I was in trouble pulling off the wheel when it was noticed the axle was hollow and it looked like one of those special expensive BMW tools would be needed for removal. Found an old 13/16th sparkplug socket with the end machined for a box end wrench (very common socket)if you choose not to use a rachet. The 13/16th end fits nicely in the axle. Loosen up the locking bolt on the fork tube, attach vise grips to the socket, and turn the bolt. Axle bolt is only about 20-25 foot pounds if not mistaken and makes for an easy turn with vise grips. Another way is picking up a bolt with a 13/16th head, pick up two patching thread nuts for the bolt, thread both onto the bolt, tighten nuts in opposite directions, and place head of bolt into the axle for removal. Using this homebuilt tool, one could use a torque wrench for proper spec tighten. Link to comment
lkraus Posted April 21, 2014 Share Posted April 21, 2014 Found an old 13/16th sparkplug socket with the end machined for a box end wrench (very common socket)if you choose not to use a rachet. The 13/16th end fits nicely in the axle. Loosen up the locking bolt on the fork tube, attach vise grips to the socket, and turn the bolt. You found the first half of the solution. Instead of vise grips, put the socket on the end of an extension, backwards. That is, put the extension in from the 13/16" end. This lets you use your ratchet handle and torque wrench. Link to comment
Tri750 Posted April 21, 2014 Share Posted April 21, 2014 Motion Pro or Bikemaster makes the correct tool as well. From about 20.00 Link to comment
KER Posted April 22, 2014 Share Posted April 22, 2014 got a few of these, works great. axle tool Link to comment
6speedTi Posted April 22, 2014 Share Posted April 22, 2014 For a small price get the right tool for the job. We are talking about a front wheel. At what price are you willing to settle for riding down the highway at 70 plus MPH? Proper torquing is critical on the wheel bolt and the pinch bolt. Link to comment
David13 Posted April 22, 2014 Share Posted April 22, 2014 And the wrong tool can chew up the axle, also. That tool that KER has will fit 2 or 4 different sizes, and those fit more than just the BMW. I know they fit the Hayabusa and probably a few other bikes as well. dc Link to comment
David R Posted April 24, 2014 Share Posted April 24, 2014 I found a 21mm long hex. I cut it to about 3" long and keep a 21mm socket to drive it. The socket fits on my torque wrench too. I found it strange that the tool kit in my 12 R1200R doesn't even have tools to remove front and rear wheel. It does now. David Link to comment
Forester Posted May 18, 2014 Share Posted May 18, 2014 Good tips. As long as it fits tight with no slop, it will do the job. Agree it's important on the install to be able to torque to specs....with a quality calibrated torque wrench. ( not the $39 versions). Link to comment
Dave_in_TX Posted May 18, 2014 Share Posted May 18, 2014 Agree it's important on the install to be able to torque to specs....with a quality calibrated torque wrench. ( not the $39 versions). Although the durability of the cheap torque wrenches may be questionable, there an old thread on this DB that indicates their accuracy is good enough. Some posters checked accuracy of some cheap torque wrenches using calibration equipment or against expensive torque wrenches. The cheap wrenches did fine. Link to comment
Nathan Margolis Posted May 23, 2014 Author Share Posted May 23, 2014 Cheap torque wrenches do fine for what most of us are doing. Have checked my cheap one with a high dollar and right on. Sure there are some that are slightly off but have purchased expensive caliperation equipment and had them off too. We are not building $10,000 race engines. If I was twisting on head bolts, main bearing caps, or even rod bearing caps- yea then I might purchase a top end wrench or borrow one. Working on my ole '73 Triumph the other day (pulled front wheel for new tire)and looking for torque specs for axle and end caps. There are none anywhere. They address by saying "tighten until snug" or "tighen until very secure". Bet you old Harley manuals say the same. Link to comment
HDH Posted June 2, 2014 Share Posted June 2, 2014 The reason I started riding Beemers is the fact that these are quality built bikes. The reason that I do all the work on my own bikes and cars is the fact that I want it done right. Why work on these bikes with vice grips other tools that were not made for BMW bikes? I say if you work on your own bikes, BMW or other, get some decent tools. Also, regarding torque wrenches, you'll need at least 2 or 3 wrenches if you do all your own work on the bike. Small wrench for the lower torque range and bigger wrenches for the bigger fasteners. Link to comment
HDH Posted June 2, 2014 Share Posted June 2, 2014 Found an old 13/16th sparkplug socket with the end machined for a box end wrench (very common socket)if you choose not to use a rachet. The 13/16th end fits nicely in the axle. Loosen up the locking bolt on the fork tube, attach vise grips to the socket, and turn the bolt. Axle bolt is only about 20-25 foot pounds if not mistaken and makes for an easy turn with vise grips. Axle torque for the M24x1.5mm axle is 50 Nm (37 ft-lbs) Link to comment
Tech1 Posted June 3, 2014 Share Posted June 3, 2014 No need to use a vice grips, use a short extension into the female hex end of the socket. Perfect fit, can use a torque wrench or standard ratchet. Link to comment
HDH Posted June 3, 2014 Share Posted June 3, 2014 No need to use a vice grips, use a short extension into the female hex end of the socket. Perfect fit, can use a torque wrench or standard ratchet. I use an aluminum tool made by Marc Parnes. You can take it with you in the tool kit and use a pin or wrench if you need to remove the wheel on the road. You can torque it later with torque wrench and regular socket. Marc Parnes Link to comment
dirtrider Posted June 3, 2014 Share Posted June 3, 2014 Morning------ Or, simply buy a 5/8" rod coupling nut (those are 13/16"od & about 2-1/4" long (about $3.00 @ Lowes or Homedepot). They can be as cheap as $1.89 at some do-it-yourself stores. The coupling nut works great, easy to carry & IF you drill a hole through one end you can use anything from a screwdriver, to a nail, to ??? to slide through the hole & undo the axle. If like me & every ounce added to a bike makes a difference then drill the center out to a larger hole size (basically core it) & drill a few more side holes. It then weighs next to nothing & is easy to carry. At only a few dollars each you can squirrel one away on your bike (or bikes) & put one in each home tool box so you don't have to dig around in your bikes tool kit at every front tire change. Link to comment
awagnon Posted June 5, 2014 Share Posted June 5, 2014 Or you can just drill a hole through your reversed socket and stick a screwdriver through it. However, at home I used my short socket extension and the torque wrench. Link to comment
longjohn Posted June 12, 2014 Share Posted June 12, 2014 I use an aluminum tool made by Marc Parnes. You can take it with you in the tool kit and use a pin or wrench if you need to remove the wheel on the road. You can torque it later with torque wrench and regular socket. Marc Parnes I'm always amazed at how light that tool is. Link to comment
HDH Posted June 12, 2014 Share Posted June 12, 2014 I use an aluminum tool made by Marc Parnes. You can take it with you in the tool kit and use a pin or wrench if you need to remove the wheel on the road. You can torque it later with torque wrench and regular socket. Marc Parnes I'm always amazed at how light that tool is. That's right, weighs next to nothing and fits perfectly with the rest of the tools underneath the seat. Link to comment
na1g Posted June 16, 2014 Share Posted June 16, 2014 Am I the only one who thinks BMW should include the tool in the tool kit of a $20,000 motorcycle? Wasn't BMW once known for providing a good quality tool kit? pete '11 RT Link to comment
dirtrider Posted June 16, 2014 Share Posted June 16, 2014 Evening Pete The big thing in motorcycles now is low advertised weight, less weight than an older model, less weight than a competing model. If BMW puts extra tools in the bike's tool kit they then have to include that in the bike's advertised weight. If they leave tools out of the tool kit that not only lowers the bike's advertised weight but saves the company money to boot (win/win for the MoCo). Link to comment
