KER Posted April 11, 2014 Share Posted April 11, 2014 Just got my new '14 RTP and have about 100 miles on it. Noticed since the day I took it home some front end shudder when using the front brakes. Used it today and got a good feel for it and now for sure feel a noticeable shudder when using the front brakes. Rides smooth otherwise and the brakes function but there is a something going on. Already have an appointment to take it in to get looked at but I'm just curious if anyone else has experienced something similar? Used a dial indicator to check the run-out on the rotors and both seem seem normal, checked the pads and both look normal. Guess I will have to wait and see what the dealer says. **What got me thinking even more when riding it was how did a tech do the pre-delivery test ride and not notice this major issue? I noticed it immediately when I left the dealer the day I took it home. Link to comment
tkrandall Posted April 11, 2014 Share Posted April 11, 2014 My '14 R1200RT front brakes do not shudder. Link to comment
lkchris Posted April 12, 2014 Share Posted April 12, 2014 Get it fixed under warranty. Link to comment
racer7 Posted April 20, 2014 Share Posted April 20, 2014 First thing to do is try some normal break in procedures. Using brakes too gently on new machinery can create problems. If that doesn't work, then perhaps there is an actual mechanical issue. Do a half dozen partial stops fairly hard (not into the ABS) from 50 or 60 to about 20. Not complete stops. Doing a lot more stops is not better- you don't want to overheat anything. Full stops are also not better.. Then let the pads cure overnight and repeat the procedure once more. If that doesn't fix your problem it may be mechanical so should be looked at by your dealer. Two things need to exist for pads to work well and smoothly 1) Pad material deposition layer on rotor (not easy to see, often invisible) 2) Bedded mechanical contact between rotor and pad That's what break in procedures are intended to accomplish Link to comment
KER Posted April 22, 2014 Author Share Posted April 22, 2014 Dealer replaced both front rotors. There was a slight run-out on both rotors. Have only been able to ride it home from the dealer but feels much smoother now. Link to comment
Tourmaster Posted April 23, 2014 Share Posted April 23, 2014 I had both front rotors (and pads) replaced on my '12 RT, both were warped at the 10,000 km (6k mi) service, felt more like a pulsation then a shutter. Link to comment
Forester Posted May 18, 2014 Share Posted May 18, 2014 Used a dial indicator to check the run-out on the rotors and both seem seem normal Maybe time for a better Truing stand? Btw, what is the factory acceptable runout? Link to comment
