bmwdavid Posted April 3, 2014 Share Posted April 3, 2014 I have the BMW Can Bus charger for 2005 and later BMW with AGM battery. Will this work with the 2014 1200RT? Link to comment
Pete M Posted April 3, 2014 Share Posted April 3, 2014 I would think so,due to the fact the canbus chargers trick the computer allowing charge. As with your 05 you can use the accessorie plug for charging. I have the $70 BMW charger which requires a harness to be installed to the battery for plug in. Link to comment
dirtrider Posted April 3, 2014 Share Posted April 3, 2014 Morning David What BMW charger do you have, the old 71607688865 or the updated 71607722471 ? In any case (according to BMW) the 71607722471 works for both the Gel & the AGM (most RTs came with the Gel battery & some GS/GS-A 's came with the AGM). As far a working with your 2014 I can't say, you will probably have to call your selling dealer to be certain what you have will work on the new 2014 bikes. Link to comment
