Sign in to follow this
ncsonderman
Actual vs. Speedo indicated?
ncsonderman
I haven't hooked up a GPS to the GSA yet and wonder if someone can share what my actual speed is at different speeds vs. my speedo? I know on my RT that I am only travelling 72 when my speedo lies and says I'm doing 80.
Thanks for the help. Better safe than pulled over :/
Share this post
Link to post
Tri750
I forget the formula that BMW used to use. It was something like 3 or 5 percent plus 2 miles an hour.
If you say 7 mph optimistic, your likely right there.
Share this post
Link to post
dirtrider
Morning Joe
Motorcycle speedometer indicated speed is a difficult thing to pin down.
The basic US & European rule is that the vehicle's (actual) travel speed should never be higher than the (speedometer) indicated speed. That is a tough thing to always assure as tire diameter, tire type, tire wear, tire temperature, tire pressure, load on the tire, & tire construction all play a role in how the speedometer reads the tire distance traveled per revolution.
Then on the GS, GS-A there are so many tire types & lug depths that trying to predict the speedometer accuracy is a guess at best.
Assuming the BMW GS, GS-A doesn't get a different speedometer calibration for US import it probably runs under the (UNECE) regulations of indicated speed should not be more than 110% of actual speed + 4 km/h.
Most late model BMW GS,GS-A speedometers that I have had my GPS on run about 5+mph fast @50mph & a little over 10+mph fast at 100 mph.
My Hexhead GS-A OEM speedometer runs about 7mph fast at 60mph & close to 15mph fast at 100 mph with worn TKC80's on it.
To really know what your bike is doing you need to run a timed mile, or use a (good) GPS on a flat level road running with the tire type/brand , air pressure, & load you want to calibrate to.
Share this post
Link to post
Haynes
It's not a linear error.
Speedo 60km/hr, GPS 56km/hr.
Speedo 100km/hr, GPS 94km/hr.
Speedo 120km/hr, GPS 114km/hr.
Share this post
Link to post
Huzband
My '08 RT was slightly worse than my current '07 GSA.
This is a shot of my speedo in west Tx on my 50cc. Cruise was set at 88mph by GPS.
I don't have a corresponding shot of the GSA speedo, but I have noticed it's much closer to the GPS than the RT was. I found last Thu on I=95 coming home from Kissimmee an indicated 82 gave me a dead on 80 GPS reading.
Share this post
Link to post
ncsonderman
Thanks gentlemen! This bike is smoother than the RT but catches the wind more. I look forward to many adventures on it. I've got to convince some friends that it isn't too pretty to take off road
Share this post
Link to post
ThomasJ
"This is a shot of my speedo in west Tx on my 50cc. Cruise was set at 88mph by GPS."
80 mph on a 50cc? that's something I would like to see! :grin:
Share this post
Link to post
Huzband
:rofl:
Share this post
Link to post
dirtrider
:rofl:
Afternoon Huzband
That would be the Iron Butt 50CC Quest not a 50cc motorcycle.
http://www.ironbutt.com/ridecerts/getdocument.cfm?DocID=4
Edited by dirtrider
Share this post
Link to post
Huzband
:rofl:
Afternoon Huzband
Yeah, yeah. Splitting grammatical hairs. ThomasJ was obviously cracking wise at my expense, & I'm still laughing about it. :grin:
Share this post
Link to post
lkchris
For sure in the Airheads and early K eras, BMW produced Service Bulletins describing "Speedometer Advance." In both versions I have, they hasten to note that the odometer is accurate.
Share this post
Link to post
