pushrod Posted January 27, 2006 Share Posted January 27, 2006 My 97 R11RT has been sitting for several months, always with Battery Tender plugged in. On a warm up ride yesterday, the ABS would not reset. Suspecting a low charge, I removed and bench charged the battery with same results. I do not hear the "reset click", and both lights continue to flash. How can I check the codes and where can I get the info for them? What would be the normal suspect, I've never had any problems before? Link to comment
russell_bynum Posted January 28, 2006 Share Posted January 28, 2006 Are the lights flashing together or alternating? Link to comment
flat_twin Posted January 28, 2006 Share Posted January 28, 2006 My 97 R11RT has been sitting for several months, always with Battery Tender plugged in. On a warm up ride yesterday, the ABS would not reset. Suspecting a low charge, I removed and bench charged the battery with same results. I do not hear the "reset click", and both lights continue to flash. How can I check the codes and where can I get the info for them? What would be the normal suspect, I've never had any problems before? Could still be a battery problem even with a fresh charge. The ABS isn't happy with the voltage it sees on start up. Link to comment
Davis Posted January 28, 2006 Share Posted January 28, 2006 If the lights flash alternating, it is still indicating a low voltage fault. If they continue flashing together then you have another reason for the fault. Take a look at IBMWR tech article for the codes. The blue connector is under the seat. Link to comment
pushrod Posted January 28, 2006 Author Share Posted January 28, 2006 I have tried the reset procedure, no luck. The lights are flashing alternatively, I'm going to check the specific gravity of the Battery, and then check for corrosion on the pin connections, and chafed wires. Just love getting the tank off..... Thanx for the pointers, might take awhile to get back to you all. Link to comment
Stan Walker Posted January 28, 2006 Share Posted January 28, 2006 Just love getting the tank off..... No need to remove the tank, the battery slides out the left side of the bike just fine. Stan Link to comment
pushrod Posted January 28, 2006 Author Share Posted January 28, 2006 I need to get to the main harness coming out of the modulator........ Link to comment
Davis Posted January 28, 2006 Share Posted January 28, 2006 Before going to the trouble to pull the tank, just attach a voltmeter to the battery terminals and measure the voltage with the ignition on. If the battery voltage is 11.8 or greater then start looking for a bad connection causing the low voltage fault, if however the battery voltage is below 11.8, just get a new battery. Link to comment
