Over Posted February 3, 2014 Share Posted February 3, 2014 So I have almost 1500 miles on the 2013 RT SE with factory radio. It replaced a 2008 model which had 80,000 miles (also had a factory radio). I swapped my CeeBailey wider and taller screen, but for some reason the 2013 model seems to flap around much more and this causes it to un screw, and it nearly fell off today ( cruise control let me tighten it up as I was riding on a freeway( motorway) with no safe stopping places... Anyone else had this ? Should I nut lock it ? Should I try and stiffen antenna with some heat shrink tube? I think the screen has something to play, as when fully retracted the antenna is much less disturbed by wind. Link to comment
Deek Posted February 4, 2014 Share Posted February 4, 2014 So I have almost 1500 miles on the 2013 RT SE with factory radio. It replaced a 2008 model which had 80,000 miles (also had a factory radio). I swapped my CeeBailey wider and taller screen, but for some reason the 2013 model seems to flap around much more and this causes it to un screw, and it nearly fell off today ( cruise control let me tighten it up as I was riding on a freeway( motorway) with no safe stopping places... Anyone else had this ? Should I nut lock it ? Should I try and stiffen antenna with some heat shrink tube? I think the screen has something to play, as when fully retracted the antenna is much less disturbed by wind. Odd. Not heard of that. I had a similar problem with my Hex Head, so I check the antenna on my Cam Head often; it's tight. I have the OWM windshield. You might run by the dealer and see what they say....although they might blame it on the CeeBaily, they might suggest a cure.....they've seen a lot of odd-ball stuff over the years..... Link to comment
Mike Posted February 4, 2014 Share Posted February 4, 2014 I'd try a internal tooth lock washer on it: Link to comment
TucTech Posted February 5, 2014 Share Posted February 5, 2014 The same thing happens to me on my 2012. I'm using the smaller CeeBailey screen. I have to regularly check and often tighten my antenna, in addition, I found that adjusting the antenna forward helps keep it still while riding. Tuck Link to comment
Over Posted February 13, 2014 Author Share Posted February 13, 2014 I removed the antenna, and see it's an M6 thread, but it's not wide enough to get a star washer on, but a small split washer and a pair of pliers ( with padding) seems to have tightened it up. I also put the antenna in its forward ( more upright) position. Only did 50 miles today, but song far so good... Link to comment
CoolTouch Posted February 15, 2014 Share Posted February 15, 2014 Try some Loctite Blue and if that still wiggles loose, try a dab of Loctite red. Both available at any autoparts store. Link to comment
Lngrdr Posted February 17, 2014 Share Posted February 17, 2014 Put Loctite on mine several months ago and no issues since. Link to comment
