bulletbill Posted January 5, 2014 Share Posted January 5, 2014 What is the best way to correct the small amount of leakage from the oil fill lid on the left valve cover? Link to comment
Boffin Posted January 5, 2014 Share Posted January 5, 2014 What is the best way to correct the small amount of leakage from the oil fill lid on the left valve cover? The best way is to fit something like This. The cheapest way is to fit a new O-ring to the plastic insert to the head and to the plug (two o-rings in total). A new insert from BMW is cheap too. The first option is permanent, the second temporary. Andy Link to comment
Selden Posted January 5, 2014 Share Posted January 5, 2014 Cheap: Clean the o-ring and the plastic seat thoroughly with 91% isopropyl alcohol. Good: Buy a new o-ring. Best: Buy a new o-ring and filler pipe assembly from a BMW dealer. Link to comment
Twinsig Posted January 6, 2014 Share Posted January 6, 2014 Take it out, take it to Napa/or other parts store and size-up a replacement for less than a buck. Link to comment
GMC Posted January 6, 2014 Share Posted January 6, 2014 Cheap: Clean the o-ring and the plastic seat thoroughly with 91% isopropyl alcohol. Good: Buy a new o-ring. Best: Buy a new o-ring and filler pipe assembly from a BMW dealer. +1 just need to clean it now and then, and then replace it when that stops working. Link to comment
Jim Moore Posted January 6, 2014 Share Posted January 6, 2014 People used to recommend a viton o-ring. They hold up a little better than the o-rings that BMW uses. Link to comment
Twinsig Posted January 6, 2014 Share Posted January 6, 2014 Cheap: Clean the o-ring and the plastic seat thoroughly with 91% isopropyl alcohol. Good: Buy a new o-ring. Best: Buy a new o-ring and filler pipe assembly from a BMW dealer. +1 just need to clean it now and then, and then replace it when that stops working. That'll work...unless the parts didnt come in. My o-ring flattened around the outer part and cleaning method failed so I went with plan-B/NAPA store. Yall know how the trip schedule goes, Link to comment
MontanaMark Posted January 7, 2014 Share Posted January 7, 2014 I've found that sometimes a little bit of grit gets lodged behind the o-ring or even the plastic seat. I've cleaned these areas out and had no leaks, at least for a while. With the location of the filler cap, hanging out in the wind (necessary, I know), it kind of begs to get polluted with foreign material. As others have said, the only fool-proof method with be the locking metal plug. Cheers, Mark Link to comment
