Shaman97 Posted December 29, 2013 Share Posted December 29, 2013 So, the rubber on the rider footpegs has taken a beating over the years. Picked up a new pair at the dealership. Got home and gave the old ones a tug - nothing moving. So is there something that needs to be removed (clip, screw, etc.) or do I shoot some 3-in-1 or dishweasher soap into the old pads and have them roll off nice 'n easy? Link to comment
Clive Liddell Posted December 29, 2013 Share Posted December 29, 2013 I have tried to remove them without cutting but eventually gave up and cut along the bottom where the rubber is quite thin... Link to comment
drtnsnw Posted December 29, 2013 Share Posted December 29, 2013 same here. It is almsot like the metal is barbed. I had to cut them off and the new ones just slid right over the metal posts. Take the scrapers off though Chris Link to comment
vbr1100rt Posted December 29, 2013 Share Posted December 29, 2013 Based on the replacement parts I just received for my 99 RT, BMW has changed the following footrest parts to polymer (from powder coated steel). 46 71 7 687 107 THRUST WASHER, LEFT 46 71 7 687 108 THRUST WASHER, RIGHT These are the pieces with 2 prongs that go into the footrest rubber, and fit against the footrest plate. The powder coating wears off the originals, and they start to rust - leaving stains on the aluminum footrest plate. You can eliminate this problem with the new parts for about $10 (for a set of 4). Link to comment
Edgar Posted December 29, 2013 Share Posted December 29, 2013 Silicone spray works pretty good for removing the stuck rubber. Clean up with soap and water and use baby power to reapply. Link to comment
