John Ranalletta Posted December 13, 2013 Share Posted December 13, 2013 Finally got 220v service to the unattached garage to run a couple of woodworking machines that have been sitting unused since Sep '12. Thought about doing it myself but stopped after digging a trench, burrowing under a sidewalk and installing 1.5" conduit, piercing the foundation walls, etc. Two electricians showed up yesterday and installed a sub panel with one 20A circuit and an outlet. I could never had done it safely. Two guys working 3 hours w/o breaks did work that would have taken me a day and posed the risk of screwing something up. Good for them. Now, I'm thinking I need a MIG rig to play with. Link to comment
SuperG Posted December 14, 2013 Share Posted December 14, 2013 that sounds like a plan. what size wire did you run out to that 20A breaker? I am no electrician but running along skinny wire and running high load like a welder can cause some pretty good voltage drop. Forget the MIG, go for a TIG. If you want to play with something it gives countless hours of play. It can do many more thing (alu, stainless, braze with silicon bronze where low heat is needed - thinner material), mild steel of course. And my favorite! you can lay some serious heat quickly on metal (moving the arc/torch around without adding filler material), if you need to get something red/white hot for bending or shaping. If you just starting out with welding, learning TIG is harder but 10 times more rewarding than MIG. MIG/FLUX is great for for fast productions on mild steel, alu or stainless requires special gas and mig-gun. Thermal arc -advanced square wave TIG is may favorite. Small form, light portable, inverter based Ac/DC TIG/Stick welder. I think everybody should own at least one! Link to comment
John Ranalletta Posted December 14, 2013 Author Share Posted December 14, 2013 The wire is Southwire SER Aluminum Three Conductor With Bare Ground, 3/AWG 2, 1/AWG 4. I think it has a 100A capacity. I've only had one 20A circuit installed for the saws, the largest of which pulls 15A. I think there's enough cap. for a Mig or Tig. Heck, the videos I've seen of some of the 120v units are amazing. The could run on a genset. Link to comment
