outpost22 Posted January 23, 2006 Share Posted January 23, 2006 My Tach has been fogging up on my '96 R11RT. Is this a sealed gauge? Is there any cure other than replacement? Thanks. Link to comment
nrp Posted January 23, 2006 Share Posted January 23, 2006 Put it in a vaccum chamber for a few minutes. Possibly heat alone might do it, but I've done the vacuum bit to watches with good results. Now where to find a vaccum........? Link to comment
Ken H. Posted January 23, 2006 Share Posted January 23, 2006 Recently discussed here - Tach Thread Link to comment
DogGone Posted January 24, 2006 Share Posted January 24, 2006 My Tach has been fogging up on my '96 R11RT. Is this a sealed gauge? ... Not anymore, the oven trick should work but it will most likely be a temporary fix. Leave it in long enough to bake the moisture out. A few hours at the oven's lowest setting. Serve smothered in onions with a nice riesling. pete Link to comment
outpost22 Posted January 24, 2006 Author Share Posted January 24, 2006 My Tach has been fogging up on my '96 R11RT. Is this a sealed gauge? ... Serve smothered in onions with a nice riesling. pete My momma always said that if you put it in front of me, I'd eat it. I will try the oven trick. Link to comment
