PAS Posted November 18, 2013 Share Posted November 18, 2013 My 03 R1150RT came with the Mickey mouse mirrors installed. I need to remove them but dont have a wrench or socket that works. Anyone know what it takes to loosen the nuts underneath the grips? Link to comment
AndyS Posted November 19, 2013 Share Posted November 19, 2013 What Mickey Mouse mirrors? Do you mean GS style handlebar mirrors? Link to comment
PAS Posted November 19, 2013 Author Share Posted November 19, 2013 Yes the round GS mirrors. It seems like a thin wall socket is needed but I have no clue what size the nut is. Link to comment
AndyS Posted November 19, 2013 Share Posted November 19, 2013 According to the Parts list it is an M8 nut. If that is so, the 'normal' AF measurement is 13mm. Link to comment
PAS Posted November 19, 2013 Author Share Posted November 19, 2013 They are actual hex nuts. The parts list shows the nuts as 8M but the price tells me they are something other then a standard nut. $8.17 each. I think they are supposed to be a special cylindrical nut with an internal allen head. I have no clue how these were installed due to clearance problems with the housing. Link to comment
PAS Posted November 19, 2013 Author Share Posted November 19, 2013 Here is how it should have been assembled. Mine has nylok hex nuts instead Link to comment
dazzz Posted November 19, 2013 Share Posted November 19, 2013 Would grinding the proper box end wrench almost flat help? Link to comment
PAS Posted November 19, 2013 Author Share Posted November 19, 2013 I dont think it would. Someone probably put the flat blade of a screw driver against the flat on the hex nut to jam it in the housing and spun the mirror stalk to tighten it. Link to comment
MarkShelley Posted November 20, 2013 Share Posted November 20, 2013 I have an 1100GS and it is a tight fit for a C spanner. I can`t get my smallest spanner anywhere near fully onto the nut, but I can just catch it enough to `lock` it so the mirror can be spinned to unscrew it. It is a bad design. Link to comment
