CharlieC Posted January 22, 2006 Share Posted January 22, 2006 I was in the process of putting on a set of Throttlemeisters and the allen head bolt holding the right side bar end stripped (is now a round instead of hex-hole). Any suggestions on getting the little beast out? It is obviously in there VERY tight. I would leave it but I'm now half and half. I hosed it with WD40 but that didn't work. Thanks for the help. [i hate for my first post to be so stupid!] Link to comment
TPadden Posted January 22, 2006 Share Posted January 22, 2006 I was in the process of putting on a set of Throttlemeisters and the allen head bolt holding the right side bar end stripped (is now a round instead of hex-hole). Any suggestions on getting the little beast out? It is obviously in there VERY tight. I would leave it but I'm now half and half. I hosed it with WD40 but that didn't work. Thanks for the help. [i hate for my first post to be so stupid!] Perhaps others will have a better solution - I'd just drill the hex head off, remove the bar end, there should now be enough shaft to grab with vice grips. Link to comment
MachineJoe Posted January 22, 2006 Share Posted January 22, 2006 Done that many times before and agree with Tom. If it's locked on that tight maybe some penetrating oil overnight will help it as well Link to comment
mountainred Posted January 22, 2006 Share Posted January 22, 2006 left hand thread tap...plug /bottom tap. It will either turn it out or you can put a left hand threaded machine screw in it and that will turn it out Link to comment
ShovelStrokeEd Posted January 22, 2006 Share Posted January 22, 2006 You might luck out and find a torx bit you can pound in there. The shock will help work against the factory Loctite as well. If memory serves, that is a 6mm bolt which takes a 4mm hex wrench. T20 or 25 might do it. Craftsman has a set of bolt extracters which might just have the right size as well. At this point, unless you have heated grips, a heat gun applied to the bar end might also help. Grip covers are cheap. Heated, not so much. Link to comment
mountainred Posted January 22, 2006 Share Posted January 22, 2006 Ed.. do the guys at pelican r1100s know you lerk here? you got a rt too? Link to comment
UberXY Posted January 22, 2006 Share Posted January 22, 2006 The advice about drilling may be the ticket. I just want to add that WD40 is not a particularly good product for loosening up stuck bolts. Try some of the more industrial quality ones, and let it sit overnight. (The local garage would not work on my wifes car recently because they couldn't get the lug nuts off with their air guns; They wanted to cut the wheel off. I put on some good penetrant, let it sit overnight, and the lug nuts came off no problem with a small 18 inch breaker.) Link to comment
PETDOC Posted January 22, 2006 Share Posted January 22, 2006 Had a similar problem. Drilled the center and inserted reverse tap only to have it snap off. Yikes! Then out of desperation got a torx bit that was a tad too big for hole, tapped it in with hammer and presto. Hope it works for you. Link to comment
ShovelStrokeEd Posted January 22, 2006 Share Posted January 22, 2006 Uber, that would be great except for one little thing, the bolt is not stuck it is held in place by an adhesive. In this case, no amount of penetrant will work. Needs either sufficient force to break the penetrant or heat to defeat it. It probably is simpler just to drill the bolt clean out till the bar end weight will slide off by itself. A little larger hole in the bar end could easily be taken up with a small washer. Link to comment
nrp Posted January 22, 2006 Share Posted January 22, 2006 Let me guess - it was one of those darn plated hex keys. Next time use black oxided ones. Link to comment
CharlieC Posted January 23, 2006 Author Share Posted January 23, 2006 Thanks to ALL who responded! It drilled out nicely and by the time the bar end fell off, the locktite had given up the fight and the bolt came out meekly. The TM is working dandily (and the red ring looks like it was made for my 1-week-old red 03 RT!) Link to comment
