Defuller Posted August 5, 2013 Share Posted August 5, 2013 Just picked up my father in laws 1981 bmw r65. It was redone in 2001 but has been setting for 12 years now. I went thought all fuel line an oil and replaced filters and cleaned tanks. The problem is it will turn over and idle great but it Hesitate between 1500 RPMs and 2500 RPMs. After that its seems to reve fine.?? What is the Problem any ideals ??? Thanks Eric in texas Link to comment
Guest Kakugo Posted August 5, 2013 Share Posted August 5, 2013 Very hard to diagnose from a distance but sounds like the carburetors need some attention. Maybe the slow jets are partially blocked, maybe one slide is slightly sticky at that throttle openng, maybe the carburetors need synching, maybe... No matter how carefully the bike was stored after more than ten years the carburetors will definitely need stripping and inspecting. Link to comment
Defuller Posted August 5, 2013 Author Share Posted August 5, 2013 Thanks for the reply. I took the left carb float cover off and Man lots of muck in it and on main jet so I took the carb off and cleaned it all out. Right side looked good. New gaskets are on way should be ready to fire up Wednesday. Wish me luck Eric in texas Link to comment
Guest Kakugo Posted August 6, 2013 Share Posted August 6, 2013 You will probably need to strip the carbs and check the jets. Muck that forms in there can be pretty tricky to remove. Link to comment
lkchris Posted August 7, 2013 Share Posted August 7, 2013 It's going to need new diaphragms. Link to comment
