Lester V Posted July 16, 2013 Share Posted July 16, 2013 2011 1200RT. 20k miles. The bearing between the swing arm and the final drive unit ...in particular the final drive unit bearing on the left ( tire) side continues to collect dirt around the circumference of the bearing/seal. After a few thousand miles I get the dark/dirt covering the pivot pin/isa screw etc. I clean it off and it appears again. Everything around it stays clean. I this a possible seal or bearing (17x 40x 13.25) leak and are both under warranty? All is good on the right side pivot pin. Link to comment
RTJohn Posted July 17, 2013 Share Posted July 17, 2013 Mine is doing the exact same thing. I don't think it's a problem. I clean it off now and then and keep an eye on it. Link to comment
racer7 Posted July 17, 2013 Share Posted July 17, 2013 Not likely a real issue. A little grease is normal. They may eventually wear out but at this low mileage that's unlikely.. Link to comment
Lester V Posted July 18, 2013 Author Share Posted July 18, 2013 Thanks guys, I've put a 'watch' on it anyway and will continue to monitor... Anyone had their bearing/seal replaced under warranty for symptoms like this? Link to comment
SWB Posted July 27, 2013 Share Posted July 27, 2013 2011 1200RT. 20k miles. The bearing between the swing arm and the final drive unit ...in particular the final drive unit bearing on the left ( tire) side continues to collect dirt around the circumference of the bearing/seal. After a few thousand miles I get the dark/dirt covering the pivot pin/isa screw etc. I clean it off and it appears again. Everything around it stays clean. I this a possible seal or bearing (17x 40x 13.25) leak and are both under warranty? All is good on the right side pivot pin. If that's the bearing I'm thinking of, and things haven't changed too much since I had my old R1100RT apart, those would be needle bearings, not sealed ball bearings, and I would expect some weeping. You might want to pull up a parts breakdown from one of the BMW dealer sites (e.g. A&S) and take a look. Otherwise, it they are sealed bearings, I'd agree with you, sealed means no weeping, e.g. dust maybe but no grease. Link to comment
