gjnockie Posted January 14, 2006 Share Posted January 14, 2006 Anyone know if you loosen the 1 torx bolt bolt at the inside end of the brake and clutch housings if you can adjust the angle of the levers? Mine do not seem to be even, also what would be the proper setting in ft lbs. to re-tighten the bolts? Anyone else have this problem? Gjnockie 2005 R 1200RT Link to comment
apm Posted January 15, 2006 Share Posted January 15, 2006 I don't have uneven levers. Why don't you just take the bike to the dealer for them to adjust - free? Tony. Link to comment
FIRST_BEEMER Posted January 15, 2006 Share Posted January 15, 2006 Don`t turn anything inside the master cylinders. The levers them self have an adjuster cam on the top. Use that adjustment only. Link to comment
Jim VonBaden Posted January 16, 2006 Share Posted January 16, 2006 Don`t turn anything inside the master cylinders. The levers them self have an adjuster cam on the top. Use that adjustment only. I think he meant the angle of the levers, not the reach of them. Jim Link to comment
FIRST_BEEMER Posted January 16, 2006 Share Posted January 16, 2006 DOH! Now that you pointed that out I re-read his post. Thanks. Link to comment
