awagnon Posted January 10, 2013 Share Posted January 10, 2013 I finally got around to rewiring the accessory outlets and adding some to the used 2009 RT I recently bought. I couldn't see paying $60+ for one of the fuse boxes like Fuzebox, Centec, etc. for just a fancy fuse holder. Instead I bought a watertight fuse box from a local hardware store for $12 and added some scraps of metal I had around. The cover of the fuse box has a rubber gasket and looks water proof. I've seen them online for cheaper. The left three fuses are wired directly to the battery and the right three are after an ignition-triggered relay. The relay is mounted to an aluminum bracket with a ground buss. I have two unused fuse slots left. Just thought I'd post pictures in case someone wanted an alternate for the standard fuse boxes. As seen from the right side of the bike: As seen from the left rear: Link to comment
w2ge Posted January 10, 2013 Share Posted January 10, 2013 Nice clean job.. very impressive. Link to comment
roundy Posted January 10, 2013 Share Posted January 10, 2013 Very tidy job that, I like - heat shrink ahoy! Link to comment
Damian Posted January 11, 2013 Share Posted January 11, 2013 Very nice. Economical too :-) Where did you find the ground buss? URL? Thanks! Link to comment
awagnon Posted January 12, 2013 Author Share Posted January 12, 2013 Where did you find the ground buss? Made it from a piece of 1/2" square aluminum bar stock. Drilled six holes and tapped them for 8 X 32 - 1/2" screws. It's mounted with flathead screws from behind. Actually you could just use the aluminum plate with screws into it for simplicity. I was bored. Link to comment
motosport Posted January 21, 2013 Share Posted January 21, 2013 It's great to see clean electrical add ons. Where did you pick up the switched hot from? Have you had any problems with the CAN BUS sensing additional load? Thanks. Link to comment
awagnon Posted January 23, 2013 Author Share Posted January 23, 2013 It's great to see clean electrical add ons. Where did you pick up the switched hot from? Have you had any problems with the CAN BUS sensing additional load? Thanks. I used the left rear passenger accessory port wire for my relay trigger. Haven't had any problems. The CANbus doesn't see any of this load since it's all direct to the battery except the relay trigger which uses very little power. I replaced all of the lower capacity accessory outlets with higher capacity outlets and larger capacity wires while at it. Link to comment
