DaveyMac Posted January 3, 2006 Share Posted January 3, 2006 Any body have the part #'s for 1100rt. Dave Link to comment
Ken H. Posted January 3, 2006 Share Posted January 3, 2006 Presuming you mean the neutral light / gear selection indicator switch on the rear of the tranny - 61312306202 Link to comment
DaveyMac Posted January 3, 2006 Author Share Posted January 3, 2006 Yes, I did & Thank you agian Ken. BTW does that include a updated O-ring, that some others have talk about. Dave Link to comment
Ken H. Posted January 3, 2006 Share Posted January 3, 2006 BTW does that include a updated O-ring, that some others have talk about?I thing so, but regardless, the # for the O-ring is 23311341836 Link to comment
Stan Walker Posted January 3, 2006 Share Posted January 3, 2006 You will also need the shaft seal 23 31 1 340 363 Mine did not come with an O ring, or a new seal. Stan Link to comment
Stan Walker Posted January 3, 2006 Share Posted January 3, 2006 Presuming you mean the neutral light / gear selection indicator switch on the rear of the tranny - 61312306202 This part is only the neutral light indicator switch. The gear selection indicator switch is a seperate assembly mounted to the back side of the neutral switch. Stan Link to comment
DaveyMac Posted January 3, 2006 Author Share Posted January 3, 2006 Thax's Stan getting what I'll need in advance."Infomus SplineLube" Dave Link to comment
Jeff from Massachusetts Posted January 13, 2006 Share Posted January 13, 2006 I am in the process of replacing my neutral switch. Here is what I learned. After following all the good advice on drive shaft/swing arm removal I got to the switch. First you remove two screws holding the two switches together. Then slide off the gear position indicator switch. Then you must pry a little to get the neutral switch loose and slide it off. This is where some confusion started. Gear oil will start leaking out from around shaft, a quick look at shaft shows there is no seal there as you can see the bearing. This is when I found out the seal is actually part of the neutral switch which the parts guy at the dealer said was complete even after I specifically asked. So I had to order the seal and put the old switch back in place to stop the oil leak. So the lesson is to replace the switch make sure you order three parts, the switch, the O ring, and the seal (which fits in the back of the switch) Link to comment
DaveyMac Posted January 14, 2006 Author Share Posted January 14, 2006 Thanks Jeff, I picked up a switch from another board member,I'll get seal & o-ring along with other stuff from my dealer. Link to comment
Frank Cloud Posted January 15, 2006 Share Posted January 15, 2006 I've lived with a flaky neutral switch from 1999-2004. In 2005 the thing started consitently lighting again and has been working for a year. Link to comment
Jeff from Massachusetts Posted January 15, 2006 Share Posted January 15, 2006 I Few pics of neutral switch project. You can see old switch in place to prevent oil from dripping out along shaft. The gear indicator switch would normally be mounted on top piggybacked. Link to comment
