bmweerman Posted December 31, 2005 Share Posted December 31, 2005 Hey Everybody Back from 10 days in TN and back on the job with this clutch replacement that wont die project. Ready to pull the tranny out now but, once again using Ted's video as my guide, it seems I need some guide pins to put in place of the tranny bolts to guide it on and off during removal/ instillation. Is that true? And if so...any clue where to get those suckers? As always...TIA Link to comment
Joe Frickin' Friday Posted December 31, 2005 Share Posted December 31, 2005 Get some long metric bolts - M8, I think, though someone else will have to confirm, or you could just take one of the bolts out and get 3 or 4 matching diameter (but much longer) bolts - and then cut the heads off of 'em. That's whut I dun. Link to comment
smiller Posted December 31, 2005 Share Posted December 31, 2005 Yep, a few M8 bolts of about 4"-5" in length (you can get by with two but I think using four makes things a bit easier), then just cut the heads off. You can do it without the guide bolts entirely if you are very careful but you will run a risk of bending the clutch pushrod. Best to spend a few bucks and make yourself a set. Link to comment
bmweerman Posted December 31, 2005 Author Share Posted December 31, 2005 That's whut I dun. Hot Damn 'yall... Thank yeee.. Link to comment
bmweerman Posted December 31, 2005 Author Share Posted December 31, 2005 Thanks for the confirmation and further info...!! So let it me written...so let it be done!! One of thsese days I may actually have a motorcycle again...he he! Live Long and prosper!! Link to comment
