Tub Posted December 29, 2005 Share Posted December 29, 2005 Yesterday, I went out to take the 03 RT for a ride to the Barbershop. It has been sitting for about two months. When I turned the key, no dash lights, completely dead. I have yet to try to charge the battery and was wondering if there is something more sinister I need to be considering? Assuming I need a new battery, I have read about the Odyssey battery on this site. Sounds like that is the one of the recommended ways to go. What is the recommended place to purchase an Odessey and is there any other watch outs I should be looking for? Tub Link to comment
BigArn Posted December 29, 2005 Share Posted December 29, 2005 This is the site I bought my Oddesy battery at. https://www.batteries4everything.com/index.html Link to comment
SC_Jack Posted December 29, 2005 Share Posted December 29, 2005 You need the Odyssey PC680. Another source: http://motors.search.ebay.com/search/sea...o=&saprchi= Link to comment
No_Twilight Posted December 29, 2005 Share Posted December 29, 2005 Tub, Money is tight around here right now so I would try charging it first. If reliability is a bigger priority for you, then I agree with the Odyssey recommendation. No more often than you've been riding it a trickle charger might just make everything better. You can buy a cheap one at Harbor Freight or most motorcycle stores for around $10 and many of us here think they are as good as the expensive battery tenders. Cheers, Jerry Link to comment
Tub Posted December 29, 2005 Author Share Posted December 29, 2005 Jerry, Thanks. I have (had) four Battery Tenders, 2 6v for the old bikes, and 2 12v for the two RT's. Unfortunately, the one on the newer RT must have crapped out on me, as I found it w/o any lights and buzzing loudly. Just ordered a new one to replace this one. I am hoping it is a battery and not some other power drain that I am not aware. Tub Link to comment
RockLives Posted December 29, 2005 Share Posted December 29, 2005 My 2004Rt had the same problems..Replaced the anemic Gel cell with the P680, the P680 is great and here is a quote from the web site """This is a true no maintenance battery. It will not spill acid and it has great vibration resistance. This battery can be mounted in any position except upside down. It does not need to be trickle charging over the winter... it maintains up to 50% of charge for over 2 years. This is the only motorcycle battery to offer you a two year free replacement warranty. This battery comes fully charged and is ready to install." Link to comment
Husker Red Posted December 30, 2005 Share Posted December 30, 2005 My pc680 just arrived today. I'll install it this weekend. Can I still use my old battery tender on it? Fortunately, I get to ride often so I rarely use the tender, but just in case. Link to comment
RockLives Posted December 30, 2005 Share Posted December 30, 2005 yes use the old tender with it..you will norice that recharge time is faster, in fact when you return from a ride or between uses. the battery will need little or no charge. Link to comment
ShovelStrokeEd Posted December 30, 2005 Share Posted December 30, 2005 in fact when you return from a ride or between uses. the battery will need little or no charge. Unless something is fracked with the charging system on the bike that statement will apply all the time. I don't use any form of maintenance charger, just depend on the charging system of the bike to keep things going and yes, that includes accessories like lights and heated clothing. My bikes sometimes sit for weeks, or even months at a time without running or any form of charger. I expect them to start right up. When they stop doing so, I just put in another battery. I do live just a few miles north of you so you are aware of our mild climate. I figure 3 years on a battery and it's pretty well toast anyway. Just part of the pleasure of owning 6 bikes and being able to ride only one at a time. Link to comment
