Steve Kolenda Posted September 2, 2012 Share Posted September 2, 2012 Anyone else experiencing an issue with throttle tension and having the heated grips on high? Today I had the heated grips on high and noticed that when I released the throttle it did not return but had to be manually returned. Problem comes and goes with heat on high. I am assuming that the grip is expanding and pressing against the bar end. Link to comment
BrianM Posted September 3, 2012 Share Posted September 3, 2012 That is the usual cause of the problem you are describing. Make some space between the grip and the barend. Link to comment
na1g Posted September 3, 2012 Share Posted September 3, 2012 I've had that problem with a couple of bikes (including my '11 RT) that have Throttlemeister throttle locks installed. They have to be shimmed very carefully to get them to work in all temps with and without the heaters on. You should be able to shim the OE bar end weight using flat washers to create enough space so the grip won't bind. Steve, up there in NH you'll be needing the heated grips real soon. pete Link to comment
dirtdreamer50 Posted September 3, 2012 Share Posted September 3, 2012 Down here in the Texas Gulf, we won't be needing the heated grips or seat until maybe Christmas. I've turned them on before just to make sure they worked. Changing of the seasons, what is that? dd50 tomp Link to comment
