Jeff98362 Posted December 27, 2005 Share Posted December 27, 2005 I'm not sure if I would drill through something important. There IS a suitable flat spot to place them at. I want to be able to strap down gear on top of the bags for an Alaska ride. Any suggestions?? Link to comment
ShovelStrokeEd Posted December 27, 2005 Share Posted December 27, 2005 Yeah, foget about the bungee buddies and just go to your local Home Depot and pick up some drawer pulls. They will allow you to use real straps rather than bungee cords which I consider dangerous. Don't get the pot metal ones. Solid brass or stainless is the ticket. Be sure to use some largish washers under the hardware to spread the load over a bigger area of the plastic. Pull through is embarrasing. Link to comment
David Posted December 27, 2005 Share Posted December 27, 2005 I don't like bungee cords. How about just using compression straps and affixing the strap around the entire bag? That's what I did on a Mexico trip, and it worked really well. Link to comment
Emoto Posted December 27, 2005 Share Posted December 27, 2005 As much as I like the OEM bags on my 1200GS, I don't think they are good for the added weight that strapping stuff on top of them would bring. The bag mounts are plastic, don't forget. If you are going solo, I would advise something like the Jesse "Solo Mount" instead, that is a plate with slots for straps that replaces the rear seat, and comes off with the key, just like the passenger seat does. It is about 1/3 of the way down this page: http://www.jesseluggage.com/rearcomp.html Link to comment
Jeff98362 Posted December 28, 2005 Author Share Posted December 28, 2005 Thanks for the good info!!! I will avoid the bungee cords. What I REALLY need to do is haul a 2.5 gallon can for a trip from Coldfoot to Deadhorse and back, while the SO is on-board. Link to comment
rideLD Posted December 28, 2005 Share Posted December 28, 2005 I had them on my system cases. Worked great. There is a perfect place to put them that does not compromise the waterproof characteristics. See pictures http://rc46.smugmug.com/photos/47770247-S.jpg http://rc46.smugmug.com/photos/47770210-S.jpg Link to comment
Jim VonBaden Posted December 28, 2005 Share Posted December 28, 2005 I agree, ROKStraps, or similar work great, and you have less chance of them coming loose, or putting excess stress on your bags. I use the Jesse bag mounts, but you can attach them to the frame as well. Jim Link to comment
Ken H. Posted December 29, 2005 Share Posted December 29, 2005 I had them on my system cases. Worked great. There is a perfect place to put them that does not compromise the waterproof characteristics. See pictures http://rc46.smugmug.com/photos/47770247-S.jpg http://rc46.smugmug.com/photos/47770210-S.jpg To and a small side note - the latch ass'y on these cases comes out easily in one piece by removing the three Phillips screws. So as to avoid the drilling into something important issue mentioned. Link to comment
