maniscar Posted December 26, 2005 Share Posted December 26, 2005 <sorry for the repeat, I posted to "oilheads" by mistake> I'm still confused about battery charging over the winter months for my '05 1200RT. I searched the posts but they seem to be more about charging through the power outlet. 1. Can I use a regular Battery Tender or Battery Tender Jr. (i.e. not the BMW version)? connected directly to the battery? I don't have the BMW outlet plugs. 2. Can I leave the battery cables connected while charging? i.e. will charging with the B/T cause damage to the CANBUS system? Or should I disconnect the cables and remove the battery? 3. I have but the B/T and B/T Jr. Does it matter which one I use (other than charging time)? Battery is BMW OEM and from what I can tell from previous posts, it's a GEL type (I haven't verified it on the bike). Thanks, Rich '05 R1200RT Link to comment
Brimoon Posted December 26, 2005 Share Posted December 26, 2005 Rich - I think you have two concerns here: 1) damage tothe CanBus system; and 2) damage to the Gel battery. Below, I've attached a copy of the "official" word from BMW which has been posted on this board several times. Contrary to what it says, a lot of folks here say they are attaching their Battery Tenders directly to the battery without disconecting it from the bike, apparently with no problem. I guess the bottom line here is to proceed at your own risk. Regarding the Gel battery. Appartently, a "regular" Battery Tender can damage a gel battery because it's output voltage can be too high. Deltran makes Tenders, including two for BMW shown below, that address this problem. I've also heard but can't confirm that the Junior model is ok to use on a gel battery. Perhaps someone else can comment on that or you can send an e-mail to Detran for an answer. Good luck - Brian Here's BMW's take on these issues: Link to comment
maniscar Posted December 27, 2005 Author Share Posted December 27, 2005 Hi Brain, Thanks for the reply. That is the info I saw on this board previously. I was concerned about the CANBUS if I connected the Battery Tender directly to the battery. However I see that Deltran makes one specifically for Gel batteries and cheaper than the BMW one: http://www.batterymart.com/battery.mv?p=DEL-021-0156 Also, the Deltran FAQ, http://batterytender.com/faqs.php, states the Jr. is safe for GEL batteries (FAQ #5): "The Battery Tender Jr. is capable of charge maintenance on all lead acid battery types, including both AGM and GEL cells." Deltran hasn't responded to my specific concern yet, so I guess to be safe I will remove the battery from the bike and use the Jr. Rich Link to comment
Richard G Posted December 27, 2005 Share Posted December 27, 2005 Here is the link for the Battery Tender selection guide. I chose the Battery Tender Plus as it says its good for the lead acid, Gel and the AGM. I used the supplied connector with the loops right to the battery connections and wire tied the cable to the frame to keep it from flopping around. I left the end just under the rear seat area. I just pop off the rear seat and plug in. http://batterytender.com/selection_guide.php Link to comment
Deans BMW Posted December 27, 2005 Share Posted December 27, 2005 The fused lead connected directly to the battery is perfect for your electric clothes as well. My R1200ST has the AGM battery and I plug in my Battery Tender Jr anytime I am not riding. Link to comment
rideLD Posted December 28, 2005 Share Posted December 28, 2005 I'm on my second winter with my Battery Tender Jr. connected directly to my R1200GS without disconnecting the battery cables. No issues at all. Link to comment
maniscar Posted December 29, 2005 Author Share Posted December 29, 2005 I'm new to BMW m/c's and not familiar with the technicals of the 1200GS. Does it have the CAN-Bus too? Rich Link to comment
TowJam Posted December 30, 2005 Share Posted December 30, 2005 I'm new to BMW m/c's and not familiar with the technicals of the 1200GS. Does it have the CAN-Bus too? Yes. All of the 1200 series boxers and the new K bikes are canbus. Link to comment
