Brad Moores Posted August 19, 2012 Share Posted August 19, 2012 Good Morning: On three occasions I have tried to start my 2011 R1200RT with no response from starter. I am then able to start it several minutes later after many tries. The service manager of the dealer has said it might be a defective kill switch and has sent me a new one to install (I live 150 miles from dealer). Anyone had this problem before? Is the new switch simply a plug and play issue. Thanks, Brad Moores Link to comment
krussell Posted August 19, 2012 Share Posted August 19, 2012 Many K1600 owners have reported issues with engine cut off and other switches. Often heat related. I don't know if it's a similar setup or vendor. Link to comment
Brad Moores Posted August 20, 2012 Author Share Posted August 20, 2012 Thanks Kevin. I failed to mention that the problem with the motor not starting occurs after the Bike has been sitting in the sun so I'm thinking you're correct it's heat related. Anyone else experience this problem? Brad Moores Link to comment
HeliMark Posted August 20, 2012 Share Posted August 20, 2012 An unfortunate issue with the newer 1200RT. Seems to even be a bigger problem with the left side switches. A lot of people are having problems. The dealers know about it and are changing them without any arguments. Link to comment
Brad Moores Posted August 21, 2012 Author Share Posted August 21, 2012 Yes. My dealer, Magic city Cycle in Orlando, FL has been very helpful through their service manager, Cory. He actually walked me through getting the motor started by pouring ice water on the switch housing. Link to comment
RichardSpag Posted August 22, 2012 Share Posted August 22, 2012 Yup, same happening here in the UK. This problem has left me stranded twice this year - not very amused Cheers Richard Link to comment
bikebits Posted August 28, 2012 Share Posted August 28, 2012 My 2011 RT had the starter button fail this past weekend. My dealer said this is a known issue and the contacts in the switch are small foil strips. Direct sunlight in high temperatures can cause enough of a dimensional change that the foil contacts won't meet. He said as an emergency measure, put an ice pack on the switch and it will start in a few minutes! As a quick fix he replaced the switch with one from a bike on the showroom floor. I got an e-mail today saying the original part number has recently been replaced with a new model and to bring the bike in for the new part when I get a chance. This has been a well-documented problem, so hopefully the new part addresses the issue. Link to comment
mneblett Posted September 1, 2012 Share Posted September 1, 2012 Add me to the club. A couple interesting tidbits from my starter/kill switch replacement today: I thought the issue was just the contacts on the starter portion of the switch failing, as I was having to push harder and harder to make contact and get the starter to turn over. Turns out there is more than one circuit (microcircuit?) in the switch body, and I had two failures going on. With the machine on the MOSS diagnostic machine, the switch was showing failure of both the starter portion AND the kill portion - apparently a second circuit which must report "enabled" to the computer to turn over the engine. Apparently BMW has been seeing some of these switch failures with the starter portion reporting a correct "start" signal, but not agreement from the kill portion to allow operation. My dealers service manager did an absolutely top-flight job at getting my problem addressed. There is a new (superseding) part number of the right switch cluster, suggesting to me that BMW finally has a new part to address the problem -- much like the infamous EWS ignition security ring failures. That's the good news. The bad news is there is zero stock in the US, and I believe none currently available from der fatherland. My service manager requested a VOR delivery of one of the few old-style switches left in the US to get my on the road, and worked me in the next day without an appointment. Yet another reason I've been dealing with this dealer since ~1980. Link to comment
RAINEY Posted September 1, 2012 Share Posted September 1, 2012 Does anyone know if they fixed these known problems on the 2012? Thanks, Jason Link to comment
mneblett Posted September 1, 2012 Share Posted September 1, 2012 Does anyone know if they fixed these known problems on the 2012? My RT is a 2012. Link to comment
RichardSpag Posted September 4, 2012 Share Posted September 4, 2012 Mine is also a 2012 Link to comment
