Gene O Posted July 7, 2012 Share Posted July 7, 2012 I've gotten the 'BMW Maintenance Plug' that fits into the connector under the steering head. I hooked up my handy multi-meter to double check which leads were negative and positive. What I discovered is that this connection doesn't go dead until 15-18 minutes after I switch the bike off. Is this normal? I would have thought that a switched connection like this wouldn't stay on more than 2 or 3 minutes at most. This is on a 2010 R1200RT. Link to comment
dirtrider Posted July 7, 2012 Share Posted July 7, 2012 Evening Gene The 15-18 minutes sounds a bit on the long side but yes that is normal for that circuit to take quite a while to shut down after key off as it is ZFE controlled. If using something like a Zumo 550 then that circuit shutting down after a while can trigger the GPS to come back on if you shut the GPS off & walk away (just something to watch out for). Link to comment
SPX Posted July 7, 2012 Share Posted July 7, 2012 I lose power from my connector after 60 seconds. 2011 R1200RT Link to comment
bikebits Posted July 7, 2012 Share Posted July 7, 2012 I lose power from my connector after 60 seconds. 2011 R1200RT I've timed it...60 seconds here as well. Link to comment
TestPilot Posted July 7, 2012 Share Posted July 7, 2012 For SPX and bikebits, are you timing with your GPS connected? The OP used a multimeter, which provides almost no load to the circuit. A GPS provides a bigger load, which may effect the time to power off. Link to comment
bikebits Posted July 7, 2012 Share Posted July 7, 2012 GPS shows power shut off 60 secs after ignition turned off. Link to comment
SPX Posted July 7, 2012 Share Posted July 7, 2012 For SPX and bikebits, are you timing with your GPS connected? The OP used a multimeter, which provides almost no load to the circuit. A GPS provides a bigger load, which may effect the time to power off. With the GPS connected... Link to comment
TestPilot Posted July 7, 2012 Share Posted July 7, 2012 In addition to load, battery voltage could be a factor. The ZFE may shut down the circuit sooner if the battery is weak. However, since BMW doesn't release much technical information about their motorcycles, this is just a guess. Link to comment
Gene O Posted July 7, 2012 Author Share Posted July 7, 2012 I tested this with the GPS attached. It still takes 15 minutes after I switch the bike off to deenergise. Maybe my ZFE is sluggish or running an extremely slow clock. As long as it switches off, I don't have to worry about having constant hot contacts on the Garmin cradle but I'm wondering if I'm running any risks mounting or dismounting the Garmin while the cradle is still hot. Link to comment
mneblett Posted July 8, 2012 Share Posted July 8, 2012 No problem pulling the GPS while the contacts are hot - I do it all the time. Link to comment
Radon222 Posted July 8, 2012 Share Posted July 8, 2012 Umm you wouldn't mind sharing the pinouts would ya? I just picked up the three wire plug yesterday Link to comment
Gene O Posted July 8, 2012 Author Share Posted July 8, 2012 There's supposed to be numbering on the plug (1-3) but I couldn't find it. Looking at the end of the maintenance plug with the three yellow wires pointed at your face, left is negative, middle is speed pulse(unused), and right is positive. Use a meter if you have one to double check. Positive is the one to connect to the red fused wire from the cradle. Negative goes to the black. Link to comment
Gene O Posted July 8, 2012 Author Share Posted July 8, 2012 I forgot to add... when looking at the maintenance connector with the wires pointed towards you, the wires should be arranged like an upside down V. Something like .'. Then the left, middle, right descriptions as posted above will be accurate. If you haven't gotten to the plug on the bike as yet, it has a cover in place that locks into a 'squeeze tab'. The connector was taped to another cable run and I couldn't get to the 'squeeze tab' until I cut it loose. (I couldn't think of the proper technical name for those little tabs that you have to squeeze to release most connectors) Link to comment
