OU71 Posted December 18, 2005 Share Posted December 18, 2005 Quick question! does the 1200RT have only a 24hour clock like the 1100 series, or does it have one you can change from 24hour to a 12am-12pm format? Thanks, Link to comment
ChrisRappl Posted December 18, 2005 Share Posted December 18, 2005 Mine displays in 12 hour format. I don't know if it can be changed to 24. Link to comment
nc1 Posted December 18, 2005 Share Posted December 18, 2005 It can be, but not by the owner - the dealer must reprogram the mode - I had mine switched at the 600 mi service - Link to comment
chopperdan Posted December 18, 2005 Share Posted December 18, 2005 On the 1100's from what I understand it was change a jumper on the back of the clock. I haven't done it yet and I don't know if it's the same. Link to comment
David_S Posted December 18, 2005 Share Posted December 18, 2005 If it's sold in the US it "should" be set up on the 12 hour format. But could be changed to 24 if that's what you want. I'm sure you could have it either way just mention it before you sign the papers Link to comment
MattS Posted December 18, 2005 Share Posted December 18, 2005 Coulda, woulda, shoulda ... I think the answer you're looking for is "definitely." Here is my 05GS telling time like a Socialist: The change, as far as I know, can only be done at the dealer (unless you figure out that it can be done by pressing the turn signal cancel fifty times in twenty seconds) ... via the CIP page, then the CKM page. Takes less than 2 minutes. Link to comment
