Canuck Posted May 29, 2012 Share Posted May 29, 2012 Does anyone else having trouble shifting from neutral to first? About 1/2 of the time I have to release the clutch and pull it in again in order to get into first. George Link to comment
BrianM Posted May 30, 2012 Share Posted May 30, 2012 Mine was like that. After first transmission oil change,it is shifting fine. Since my bike is under warranty,I just used the BMW transmission oil. Link to comment
David13 Posted May 30, 2012 Share Posted May 30, 2012 Mine too. A lot of people report that. dc Link to comment
Paul Mihalka Posted May 30, 2012 Share Posted May 30, 2012 Standard occurrence. With this clutch and gearbox, when you pull in the clutch and hold it, everything stops turning. If the gears ("dogs") are not lined up, it won't shift. Most common standard procedure is with the clutch pulled in keep soft pressure on the shift lever toward first and slowly release the clutch. It will click in. PS Welcome in this group! Link to comment
rvickery2 Posted May 30, 2012 Share Posted May 30, 2012 I learned this very same lesson being new to BMW. If you're in N and have clutch all the way to grip, it won't go into gear. Let clutch out about halfway. Also if you want to start bike in first gear you have to pull clutch all the way to grip. It won't start with clutch half pulled. You will get used to this and if you preload the shifter with your foot it will shift "as soon as you pull" the clutch lever. Link to comment
Canuck Posted May 31, 2012 Author Share Posted May 31, 2012 Thanks guys. Lots of knowledge here. Link to comment
algover Posted June 3, 2012 Share Posted June 3, 2012 Thanks guys. Lots of knowledge here. That there is. And a willingness to share it! Link to comment
