mbohn Posted December 17, 2005 Share Posted December 17, 2005 What is the coldest temperature you ever started your bike? Link to comment
94aero Posted December 17, 2005 Share Posted December 17, 2005 13 deg. And I not too proud to say thanks for Gerbing's!!!!!!!!!! Link to comment
mbohn Posted December 17, 2005 Author Share Posted December 17, 2005 Let me clarify the question: Assuming your bike spent at least 8 hours (overnight) in the low temperature. NOT "it was in my garage and then I pulled it out and it was x degress F outside and I started it." Link to comment
KER Posted December 17, 2005 Share Posted December 17, 2005 30f, outside under a covered parking spot Link to comment
270 Posted December 17, 2005 Share Posted December 17, 2005 Let me clarify the question: Assuming your bike spent at least 8 hours (overnight) in the low temperature. NOT "it was in my garage and then I pulled it out and it was x degress F outside and I started it." 12F. Middle of a parking lot. 8-10 mph wind. Sucked. It did warm up to 17F though. I rode 800 miles. I'll never be the same either. Link to comment
RockLives Posted December 17, 2005 Share Posted December 17, 2005 65f its hot in south Florida Link to comment
KMG_365 Posted December 18, 2005 Share Posted December 18, 2005 about 30*F at the Death Valley pre-run last year (after leaving my fuse block hot all night, 'cause I forgot to lock my forks again after showing off my Russell saddle! ) I wish I'd known then about the dang "pull in the clutch lever" when starting to keep from turning the tranny shaft and gears in the thick RedLine Shockproof Heavy tranny oil! It's a bit of a trick holding the fast idle lever up while holding in the clutch and thumbing the starter, but it can save you some serious cranking amps when you really need all you can get! . . . not to mention the embarassment!! Link to comment
Jake Posted December 18, 2005 Share Posted December 18, 2005 11F, then I rode outta Chi-Town for good! Link to comment
DiggerJim Posted December 18, 2005 Share Posted December 18, 2005 -1F Thursday. But I decided not to ride 'cause it was chilly out It's gotten uncommonly cold early here (CT) this year. But it was nice today (38F) so out it came for some fun in the sun. Jim Link to comment
KDeline Posted December 18, 2005 Share Posted December 18, 2005 Lots of mornings in the single digits, after sitting out all night at the work parking lot. Never more than a 3 year old Odessey battery though, just for that reason, and 10w 40 weight oil. Link to comment
Mainuh Posted December 19, 2005 Share Posted December 19, 2005 What is the coldest temperature you ever started your bike? -5F Started and rode 40 miles... No heated clothing. It was a K1100LT though. It was a bit nippy... Knew it was cold when I couldn't read the LCD display. Usually prefer 20F and above. Link to comment
Parrothead Posted December 19, 2005 Share Posted December 19, 2005 10 F, that was in DC in the late 80s. Very cold ride! Link to comment
